Ka-t wont rev pass 4000RPM
Cupnoodles
What the title says, my car wont rev pass 4000rpm when i try to push full throttle. It would seem like 4000rpm is the limit on every gear. I have a JWT ecu thats set to push 7000-7500 Rpm and rev limiter taken out. Im also using a z32 maf that i jus recently cleaned with maf cleaner, changed out the coolant temp sensor, and turbo is pushing 5lbs of boost. Not shure what else to do next. Anyone has a clue on what could be the problem and can help me out? thanks in advance...
KungfuActionChad
Car: 1990 240SX Coupe
did you upgrade the fuel system after you boosted it (bigger fuel pump, bigger injectors).....that would be my only guess
slidestyle69
Car: 92 s13
MASS AIR!!!!!!!! Wiring issue
leonelrr
Car: s13,s14, z32TT, YZF R6 None of them work nothing to brag about
Same here, i think it is going to be the Mass Air flow sensor, i had the same issue with one from a SOHC
Good luck!
xpertsnowcarver
im selling a N62 and P61 maf if you're interested. and why are you only doing 5 lbs?
travisdx
Car: 1992 s13
redo grounds and make new ones that was the problem with my buddys car
