Sorry, I wasn't saying that was messing my idle up. It was just a random questionbiggie wrote:My other one is left open.
Not sure how that'd affect idle though.
I did what you said and I got it to start. It idled fine after a few seconds of it running. I drove it easy around the block a few times. But one thing I noticed is that it's not building boost if I rev it slowly. Only if I gun will it start to build boost.WDRacing wrote:I doubt it's the carb cleaner causing it not to start. It's hard to use to much of that stuff. I'd recommend brake cleaner over carb cleaner though. Autozone carries seafoam, usually 2 different sized cans. You only need the smaller one.
Has the dizzy been pulled? My idle issue was being off a tooth when I reinstalled it.
What are you using to tune the fuel/timing?
Pull the fuel pump fuse and crank it over a few times. Don't let the starter engage for more then 4-5 seconds at a time and do it 3 times. This will remove any fluids in the combustion chamber.
Put the fuse back in and try to start the car. If it starts good if not disconnect the MAF and try to start. Let us know what happens.
BTW are you absolutely sure you have no vacuum leaks? They will cause a lean condition and the motor doesn't like to idle when it's lean.
WD
Where is your wastegate line routed to.Techsalvager wrote:Check everywhere for leaks, and tighten up all lose clamps on intake piping and check the vacuum lines.
I've never heard of a flood. If you're using an external gate you attach a vacuum line to the port on the side. The other end has to be connected to either the intake manifold, usually T'd into the FPR line, or to the compressor housing. I personally don't use the compressor as a vac source. I always use the intake manifold as the same source for the boost gauge, FPR and wastegate control. The reason I use the manifold is so everything is seeing the same pressure from the same source. There is also a 1-2 psi difference between the compressor and the manifold because of the FMIC and associated piping.Nizmo-Nuts wrote: To the compressor housing.
I had a friend of mine told me that my w/g should have a flood(I think thats what it's called) Well my w/g never came with one(I bought it used ) Could that cause it to not open.
Also, what does the flood look like and where does it go.
Get a wideband before you start doing more stuffNizmo-Nuts wrote:It just won't build boost if I rev it in neutral or slowly build up my rpms.
Right now I don't have a wide band, but I'm trying to get one soon.
Thanks I'm going to order one now.WDRacing wrote:You can buy a fire ring online for your wastegate. Just google "whatever brand" fire ring and click shopping
That it def the next thing on my list to get.Techsalvager wrote:Get a wideband before you start doing more stuff
Also boost won't build up in N because there is no load\hardly any load on the engine to build iup boost. Also slowly reving up in gear won't build boost as fast either.
