I talked to another guy about the trigger angle, and he said that his optimal angle was 108 degrees. I set mine at 60 and worked up to 108 and concluded that it worked best for me too. That's why I can set the MS to a fixed timing of 20 degrees and see 20 degrees on the light, so I'm pretty sure that's all good.
480sx wrote:I see a huge problem with your setup. First of all, your saying your only idle control is the IAC-FCID valve? That is the 'AC control' valve. That would cause some serious problems. Or maybe you just have them mixed up in your head, im not sure. The main KA IAC is a thermal type fast idle valve, that only needs an on off 12 volt signal. This is the one you should be using... I have a hard time seeing your car even trying to idle with the FCID valve only, but maybe its possible. Anyway, you need to use the thermal type IAC and leave the FCID valve alone. FYI, the FCID valve is a PWM type valve.......
Uh, what? The thermal type IAC is just a bimetallic heater with a door. All that happens is that it will get constant power when the key is on. The power going through it will heat it up, and when it gets up to its normal temperature, it will close off the air supply. It's almost exactly the same principle of operation as an electric choke on a carburetor. There is no way you could use this for your idle controller.
The AC solenoid is an on/off type. It just opens when the AC is on, to kick up the idle. So far it seems like it can flow enough air to work.
The PWM valve you are talking about is the main IACV. I can't use it right now because I don't have the correct transistor installed in my megasquirt, but hopefully it will arrive in the mail soon. For now it's just not connected to anything.
Even if there were something wrong with my IAC setup, I can't see how that could cause the engine to miss..?
