I've tried everything. ****ing EVERYTHING.
Today I cleaned my maf, checked all grounds, replaced the FPR (the new one still leaks.....maybe there's a relief?), tested CTS for proper resistance, tested injectors for proper resistance, etc.
It wants to go in boost when the car is cold(still doesnt go at WOT but seems to be better)...and seems to run better when it is cold. The second it warms up it dies when I stop, and doesn't go into boost at WOT.
Found another leak today, at the throttle body...not even at the gasket, at the spring assembly thing. I'm sure that's not my damn problem anyway. Even if it was my problem under boost, WHY would my idle all of the sudden by screwed up? It never missed @ idle before.
Shoulda went SR.
