bozuzu »
https://forums.nicoclub.com/bozuzu-u16116.html
Thu May 06, 2004 11:24 pm
well, i found all the emission stuff in arizona you'll ever want to hear about!for the guy moving there, beware, you'll have to do some serious mods or drive around illegaly. check it out:all of the laws can be found at a website,
adeq legislation
and look. here's an example:
G. In addition to an emissions inspection, a vehicle is subject to a tampering inspection on at least a biennial basis if the vehicle was manufactured after the 1974 model year and the vehicle is not subject to a transient loaded emissions test. The director shall adopt vehicle configuration guidelines for the tampering inspection which shall be based on the original configuration of the vehicle when manufactured. The tampering inspection shall consist of the following:1. A visual check to determine the presence of properly installed catalytic converters.2. An examination to determine the presence of an operational air pump.H. In area A, if the vehicle was manufactured after the 1974 model year and is not subject to a transient loaded emissions test, a visual inspection for the presence or malfunction of the positive crankcase ventilation system and the evaporative control system.3. Vehicles required to be inspected shall undergo a functional test of the gas cap to determine if the cap holds pressure within limits prescribed by the director, except for any vehicle that is subject to an evaporative system integrity test.
so, if you're not convinced, call this guy:
Vehicle Aftermarket and Retrofit Devices:John Walls, VEI Section ManagerPhone: (602) 207-7027
this is THE GUY in az to talk to about aftermarket stuff. here's what i told him, and he told me. i told him that i live in oregon, have a '97 pickup with an aftermarket turbo kit and sds stand alone, tuned to get 28 mpg and appr. 30 % less than stock emissions, with a working cat. i told him i want to move to downtown phoenix (where i live).he says, '96 and up vehicles don't even get smog tested, they just run a computer obdII diagnostic. they don't care. if you have sds, obviously your obdII is long gone, so is your emission control devices, so you're best bet is to a) not move here, b) sell your car, or c) call a congressman, or the director of adeq. i'll see you in hell.
so, the verdict is in. if you want to move to phoenix, or already live there, you need to figure out a way to keep all of the emission control devices intact with your aftermarket setup, and the stock ecu, or one that will work obdII (like a jwt). otherwise, the dot will find you and take your money.
