hannibal »
https://forums.nicoclub.com/hannibal-u1252.html
Mon May 31, 2004 1:20 pm
A budget setup would be the 8:1 FMU with stock injectors. This setup can give you decent power levels, but its much less reliable(Nsport's kit uses a 8:1 FMU with a T4 running at 7psi).
Once you use the 370cc, you need something to trim them down at low RPMs to keep it from running way rich. If youre gonna use the 370cc, you dont need the FMU. With 370cc, Walbro fuel pump, and a hacked MAF, you could run up to 250whp (about 10psi on a 14b??)
hacked MAF - "free"370cc injectors - $100Walbro 255 - $100
So for a little over $200, you can run up to the limit of the hacked MAF (about 250whp)
