truth211 »
https://forums.nicoclub.com/truth211-u67171.html
Tue Apr 22, 2008 9:20 pm
I have a 1992 240sx with a ka24de-t. The engine is from a 1996 240sx and I am using the s14 upper intake and the s13 lower intake. I have removed all my emissions and all un-neccessary vacuum lines. I have one vac. from the FRP to the lower intake, BOV vac. to the lower intake, AAV/AICV hose to the cold pipe, WG to the hot pipe, 370cc sr20de-t purple top injectors, stock MAF, retuned ECU for KA-T and set-up, 3" down pipe and exhaust, No cat, T25 turbo no oil restrictor, 3" in/out FMIC and electric fan set-up. Removed a/c as well. Timed at 20* BTDC on warm idle.
So here is my problem. I accelerate from first gear and shift to second gear. I stomp on the gas (WOT) and she bucks, loses a tremendous amount of power (almost feels like it dies for a second or two) and there sounds like a popping noise when that happens. It really does it through all the gears but is most noticable in second gear. Also I have the WG set at around 7-8 psi but that puppy shoots right to 15 psi in second gear. She boosts fast to 15 in second gear. Quite strange really. But I can not figure it out.
I want to be able to mash my foot to the floor and see a max of 14 psi and have no hesitation. I want it to run strong with no more issues. Any clues to how I can accomplish it? I have spent alot of time finding threads but nothing with my particular situation. Also can 370cc injectors handle 14 psi of demand? Really I only wanted to run 10 psi max. What are your suggestions?
