Ken Park »
https://forums.nicoclub.com/ken-park-u43991.html
Mon Dec 08, 2008 5:00 am
Do yourself a favor and dont run an FMU. Those things are intended to be used on supercharged engines, which make boost differently than turbos. Superchargers usually don't run more than 10 psi average on your average supercharged V8 for instance. On a turbo engine you are gamb|ing, and you will get a very noticeable dead spot when one of those things is putting out the max it is set for. I used to run a Vortec FMU with stock injectors and big fuel pump on my KA-T, and popped the motor. It was more of an issue of timing, which I had no way of controlling, another very important factor. When the motor got rebuilt with good stuff inside I went with a tuned ECU and some 370's. That alone made so much of a difference in power and driveability.
