My DEC settings are way different from yoursBiggamehit wrote:bro that z32 maf is seriously not needed with that size turbo and injectors man and may be one of the sources of your problem i am running an N60 .. also like the person above said you have to make sure your AFC settings are correct.. i run atmospheric and i have no DEC problems at all,
here are my Dec settings for example.
Throttle=1.4%Ne1= 2.3%Ne2= 3.3%
Not yet. The car was street tunned by a local known tuner.Florida240sx wrote:Put the car on dyno or wideband?
The only way I get it started everyday is by hitting the gas while cranking. From what friends and local 240 owners tell me, the hard starting is most likely from running off the afc which pretty much jacks the timming way up. Car starts right up if I take my ratchet and turn the crank pully to the stock ka timming mark.NateDogg wrote:Hard Starting: leaky injectors, bad SAFC settings
Stalling: vented BOV, dirty IACV
Check your plugs and tell us what you find.
I'll see if I can find a wideband to borrow and post up results. In the meantime i'll play with the low settings in that range and see what happens.Florida240sx wrote:Your low setting should be next to 0% because you have 370's Go to a dyno, or borrow a wideband.Your settings are too rich for cruising which is most likely fouling out your plugs, and causing these symptoms.
Don't listen to those idiots. I've turboed 3 240's and a few other cars. All running safc. Everyone one starts and idles just fine. They feel important by lieing to you. REason why all the cars I've touched work, is because I know what's what, and I got a wideband I use to tune right off the bat to remove all doubt of rich/lean condition.GoldenLeg wrote:
The only way I get it started everyday is by hitting the gas while cranking. From what friends and local 240 owners tell me, the hard starting is most likely from running off the afc which pretty much jacks the timming way up. Car starts right up if I take my ratchet and turn the crank pully to the stock ka timming mark..
