ka-t topmount help guys!
costa_rican13
Car: 1993 s13 coupe
so im planning on boosting my ka, and i have 2 turbos, a t3 z31, and rb20 (t3 flange)t28. now i dont want to bottom mount either of these, i want to do a topmount mani. so from looking at these turbos, the turbo elbow doesnt face down. so my question is would i have to cut the elbow and turn it down and reweld it or what ideas can you guys give me to help me out with this? i also dont want to buy another turbo..my z31 turbo looks like this>>Image
P7210029 by costa_rican13, on FlickrImage
P7210030 by costa_rican13, on Flickr the t28 from the rb20 looks almost identical but slightly smaller. either way the exhaust elbow does the same thing..
s13drifter88
Car: 93 S13 Coupe CA18DET (Money pit)
1996 D21 Hardbody (Work truck/daily)
!993 Del Sol (Daily)
1987 Pontiac GTA (Drag project, other money pit)
1989 SOHC S13 Buzz Car
to do so you'll need a custom dump and some other crazy goodness. i myself wouldnt really even consider either of these. the z31 turbo is the better of the 2 tho seeing as how the z31 turbo has a standard steel exhaust wheel vs the rb20's ceramic which loves to fly apart when boosting about 13-14psi but neither of which will yeild more than about 270whp, maybe more with some good tuning.
If I were you and hell bent on a t3 top mount I would look into something like a new Precision SC50 for about $800 and an ebay cast manifold. with a little port work on the mani to clean things up a bit that setup could easily yeild 400whp. get a fmic, a set of 550's, 3" exhaust, tial 38mm wastegate and a jim wolf or enthalpy rom tune with a z32 maf and you'll have yourself a 350whp combo ready to be daily driven. if youre on a tight budget you could save a little cash on the wastegate, 2 friends of mine both run the basic $90 OBX 38mm with no problems, spikes, creep or anything (Zach for over a year-RB20 and Craig for about a year-KAT).
costa_rican13
Car: 1993 s13 coupe
well i dont really have 800 to drop on a turbo and since i already have 2 i would like to use either which both have the same problem with the exhaust elbow. so im gona get a flange and weld it up since i have a welder and blah know anywhere to get the flange??. and youre talking about 550cc injectors correct?? anywhere to get those 550cc's on the cheap?? and not classifieds already looked.
biggie
Locking this one because of the other topic:
topmount-on-the-ka-help-t521378.html
