240dx »
https://forums.nicoclub.com/240dx-u125550.html
Mon Jul 13, 2009 8:42 pm
Finally turbo tomarrow.heres the list ive accumilated over the last 6 months.Everything is in canadian dollars FYI.Im doing everything but the fab work and tuning. I understand the t3 outlet is going to be tough. IC piping is going to be welded.Im scared and excited at the same time. Im just out of high school BTWIll be pushing approx 10psi. Ill post the dyno results when it's done.Wish me luck
Garret T3 50Trim .48A/R (300$) - Used eBayTop Mount Turbo Manifold (250$) - from Japan Denso Top Feed 440 Fuel Injectors (100$) - new from eBayGReddy Intercooler (180$) - Used shipped from eBayN60 MAF (50$) - LocalProjectSylvia Top Feed Fuel Rail (50$) - LocalTune (200$) - LocalHKS SSQV (150$) - eBayTial Wastegate new (200$) – localTurbonetics MBC (50$) - ebayMegan Racing Gauges (170$) – EbAY2.5” Turbo-Back eBay Exhaust (250$) - EbayRelocate battery (80$) – LocalGauge pillar (50$) - EbayComplete Oil Feed lines (100$) –EbayDump Tube (50$) - EbayExhaust wrap (50$)- LocalAEM fic (400) - Ebay7psi Tial Spring (35$) –TialIC Piping (110$) - eBayWalbro (120) - Ebay38mm flanges for wastegate re-route (50) - VibrantNGK iridium R6 plugs (45) - localNTK o2 (100) - local
TOTAL.............................3100$ CND
not bad. about the equivilant for full sr swap. I have 180 compression all the way at 197.000 KILOS
