Structure240sx wrote:once again u better be happy about that 5spd swap. seriously i would do it all over again, might go smoother the second time.
ill talk to u on AIM
hahaha.....Dont worry Ant, im more than happy!! We are always eagered to do something until we find ourselves stuck for hours on one thing, then i wanna shoot myself. But now everything is great.
WDRacing wrote:My personal opinion on making hp goes like this, you need to pick one or the other, increase boost or timing.
Lets say your motor is limited by fuel rather then timing, you can only run said amount of boost no matter what your timing is set at. So figure out your max boost for your fuel injector duty cycle, then increase your timing until your motor starts to indicate knock, then retard 2 degree's. Unless you have a standalone and can gen up your own timing maps based on boost and load your stuck with the base timing advance.Does that make sense to anyone besides me?WD
I think it makes pefect sense. The thing is that im almost at the edge of boosting 15psi. 15psi is the max people boost the KA "safely." Thats why im trying to squeezz as much power out of ignition without turning to boost for more power. Sounds good to adjust base timming close to 20degs or turn it back down 2deg for a safety measure.
S14tat wrote:damn paul. when you set that timing right. go race with my friend with the STi again for a rematch. hehe
Lol, if he only beat me by 1 car im sure itll be a different story when i adjust timming and shift FASTERRRR.....lol I suck. Its only been a month or so, ill get better!
MarkEmark wrote:
I'm confused... You said in your post you were running 15 deg BTDC at the distributor...when you recorded that the timing was retarded to 16 deg BTDC under WOT, was the timing set at 20 deg BTDC at the distributor, with the MSD BTM set at 0 deg. retard per psi of boost? If ithe destributor wasn't at 20 deg BTDC, and it was set at 15 deg BTDC, wouldn't that mean that the ECU is not retarding the timing at all under WOT (actually increasing it 1 deg), but is staying at a relative constant 16 deg BTDC and therefore you don't actually need the MSD BTM to retard the timing?
It sounds very confusing, even to me sometimes when i go back and re-read what i posted, lolWhen we checked my ECU timing with techtom it read 16deg at WOT. I always had my dist. at 15deg thinking that it was at 20degs. So now i want to turn it up to 20deg (base timing) cause the ECU is retarding enough on its own (16degs at WOT). I dont need the MSD BTM, but i bought it and installed thinking i needed it. That was before i had the opportunity to check my ECU total timing with the Techtom.I dont know if that kinda clears things up?
klattr1 wrote:just put it at 20 deg. base timing and then recheck the total timing under WOT again with the MDM Techtom because after that the map could be in a different spot due to different load after changes.
Yeah im gonna do that tomorrow! If i hear or feel anything weird or wrong ill just adjust timming through the BTM, so i guess the BTM will serve a purpose after all, lol
Thanx everyone for your input, really appreciate it!!! I hope everything works out.
PauL
