KA-T...t25???
greenmachine240
Car: 1995 240sx
with the t25, i hear you dont have to run a whole new tune and injectors
is this true???
White Comet
Car: fc, s13 and mazda6, Sierra
you could probably get away with stock injectors with very low boost, but i can't imagine you won't need a tune or something comparable. this should be in the ka-t section for best results
Darchangl
Car: 95 240sx Ka-t (in progress)
fmu should work.. I strongly suggest you read the sticky. it covers ALL of this
boznuttz
Car: MS13
For a an SR T25, you'll be fine on the stock injectors with an 8:1 FMU and a slight retardation on your dizzy. I love saying that, lol. Just run 93 octane, but the hair dryer setup is pretty simple for a low power setup.
s13mike91
Car: 91 240sx hatch
what would they KA run like with a sr turbo t25???
boznuttz
Car: MS13
Like a heat pump, lol.
WDRacing
Good for low boost only.
hpmachine
Car: '05 EVO8 + '95 240sx
Could you even run 5 psi with that? Non-intercooled? Isn't rule of thumb (if you are not re-tuning your ecu) to back off the distributor base timing nearly a degree for every pound of boost? I'd imagine that if you ran 4lbs of boost and backed off the base timing 3 degrees, the gain in power up top wouldn't even make up for the loss at low rpm. ?????anyone????
red ka-t
Car: s13
Owners that cutt corners is what gives us Ka-ters a bad name and is the main cause of people blowing motors.
