KA-T Spark Plug Question
#1 Stunna
Hey Guys, Just wondering what kind of spark plugs you guys are running on your KA-T setups. What part number? and what are you guys gapping them to? Thanks for the help in advance.
Ivan
TomsMR2
Car: cars.. etc
id personally run stock plugs, one heat range colder.
WDRacing
Anything Iridium is a good place to start. The Gap should be .9I prefer NGK R Iridium's or Denso Iridium. They always held up the best to really high boost in my Skyline.
WD
cnichols
Car: 96 Nissan 240SX
99 Infiniti Q45
93 Ford Fastiva
I went with NGK Iridiums...one heat range colder and a smaller pre-gap of (.035") instead of (.044").
Part # - BKR6EIX-11 (stock code: 6418)
NAPA can get them to you in a day or so.
silviaNE
Car: cars what else?
denso iridiums one range colder (duhh)
DaveEEE
NGK BCP7ES... Also will take napa about a day. They are CHEAP too.
cnichols
99 Infiniti Q45
93 Ford Fastiva
What are the specs on those??? Stock gap??
The 7 means they're the stock heat range correct?
DaveEEE
You have to gap em, I set mine at 0.028.
-Dave
cnichols
99 Infiniti Q45
93 Ford Fastiva
What material? Platinum? Iridium? Copper?
DaveEEE
cnichols wrote:What material? Platinum? Iridium? Copper?
Hmm... They are just regular NGKs, probably the same good stuff the stockers are made of? No bling bling here...
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
I use the OEM Platinum plugs in a 6 heat range...gapped to .030
DaveEEE -
OEM NGKs are Platinum, hence the $8/plug cost...Standard NGKs are Copper IIRC - The one you listed is "Standard 2.6mmø center electrode" per NGK...
Read here: NGK Plug Info (What the numbers/letters mean...)
Later - Brian
ADAMHU
i use one range colder than stock, gapped 28 thou
