KA-T SOHC Build to 250HP
GlacierFreeze
Car: '97 240sx (the tortise)
Looks pretty small. You'll probably be happy with it for a while as a starter turbo.
eastreetmotorsports
Car: 91' Nissan 300zx Z32 TT, 72' Datsun 240z, 93 RX7 FD3S R1, 93' Nissan Xterra
yeah that was what i was thinking till i can get a really good turbo, free ain't bad
HaXoRsMoBiLe
Car: 2x 90' hatches KAT and RB20
Your gonna want to run bigger injectors than what was suggested, iirc, 450cc injectors at 80% duty cycle will run ~220 crank hp, now im told you dont want to run above 80% duty cycle real often since itll shorten the life of the injector majorly. if im wrong correct me, but id run at least 550's or so(precision has good prices there).good luck with the kat tho.-Paul
WDRacing
Not a bad turbo at all. They run 14psi on those often. Free is my favorite price!!!
eastreetmotorsports
so 750cc inj would you think is over kill???? i will look into the 550CC tonitea friend of mine offered to build my a header and downpipe to fit so that is more great news
14 PSI eh?? sounds good! and yes free is better
WDRacing
With fuel injectors I'd buy more then I thought I'd want...more is always better. I bought 8 42 lb injectors cause 4 seemed gay. Wired in series I have 84lbers...FTW.
WD
Dustin240
Dont know about u guys but I never could find WEISCO pistons for the SOHC. So I got Arias pistons W/8.8comp 20over and Pauter rods. I had to grind-away at the block to get the rods to fit but there so nice.
NCturbo75
Car: 2006 INFINITI M35...
eastreetmotorsports wrote:thanks! that is not a bad cost at all, i just heard so many horror stories about KA-T's blowing up cause the block and internals couldn't handle the pressure but if these bolt on's and fine tuning can help then that sounds good to me, cause that would have sucked to put down some cash and it craped out of me.
lata!
You can blow up any motor if the car is not properly tuned.
