KA-T S15 GT28R Turbo Setup Complete List
supra33202
I have my S13 Hatchback for about a year and I want to turbo my car now. I did suspension and brake upgrade already. My S13 is mainly for drifting. Since this is my first turbo car and first time to do this, please let me know if you have any suggestions/tips.
My goal for this S13: I want to have around 250-280WHP with responsive acceleration. I am interested in good response and low-end torque for drifting. I just want a typical good setup. Since I don't plan on rebuilding my KA24DE, I will run 8-10 psi boost. I did a compression test on my engine. The result is 180 psi for all 4 cylinders.
Reliability > Performance > Cost
Here is my setup:
Nissan JDM T28R Turbochargerhttp://www.thenismoshop.com/ik...d=341
NISSAN SR20 Turbo Inlethttp://www.mynismo.com/products/?id=5976
Nissan OEM SR20DET Turbo Gaskets G. 2-bolt turbo inlet tube gaskethttp://www.thenismoshop.com/ik...=1565
NISSAN SR20 Turbo Outlethttps://www.mynismo.com/products/?ID=5973
TURBO OUTLET TUBE GASKET 3 BOLT SR20DET S13 S14 S15 OEMhttp://cgi.ebay.com/ebaymotors...ories
Nissan 240SX Silvia S14 S15 SR20DET Air Intake Systemshttp://cgi.ebay.com/ebaymotors...ories
NISSAN MAXIMA MAF AIR FLOW SENSOR N60 SR20DET KA24DE NRhttp://cgi.ebay.com/ebaymotors...l1116
Nissan 240sx KA24det Turbo Manifold - T25/T28 S13 S14http://stores.shop.ebay.com/SS...earch
Megan Racing 3" SS Stainless Steel Downpipe SR20DET w/ Flex Sectionhttp://www.frsport.com/Megan-R....html
Megan Racing KYO SR20DET Exhaust Turbo Outlet Elbowhttp://www.frsport.com/Megan-R....html
Megan Racing 3 in. Test Pipe Nissan 240SXhttp://www.frsport.com/Megan-R....html
FMIC INTERCOOLER PIPING KIT BOV 240SX S13 SR20DET 89-94http://cgi.ebay.com/ebaymotors...ories
SHURiKEN SK-BT35 BATTERYhttp://www.sonicelectronix.com....html
HKS SSQV BOV SQVhttp://cgi.ebay.com/ebaymotors...A1318
HKS SSQV Recirculation Fittinghttp://www.mynismo.com/products/?ID=4793
JDM S15 SILVIA 480CC INJECTORS SR20DET S13 S14 180SXhttp://cgi.ebay.com/ebaymotors...A1318
INJECTOR SEALS SET S13 240SX SR20DET GENUINE NISSAN OEMhttp://cgi.ebay.com/ebaymotors...ories
NGK Iridium IX Spark Plugs Nissan 240SX KA24DE Turbocharged Colderhttp://www.frsport.com/NGK-Iri....html
AEM GAUGE TYPE 6-IN-1 WIDEBAND UEGO CONTROLLER 30-4100http://cgi.ebay.com/ebaymotors...ories
AEM Tru-Boost Electronic GAUGE Type CONTROLLER 30-4350http://cgi.ebay.com/ebaymotors...ories
ATI EZ POD DASH GAUGE HOLDER NISSAN 240SX S13 89-94 52Mhttp://cgi.ebay.com/ebaymotors...ories
JGS Vacuum Blockshttp://jgsturbo.com/kamain.html#anchor415357
EXEDY RACING STAGE 2 CLUTCH KIT 91-98 240SX KA24DEhttp://cgi.ebay.com/ebaymotors...ories
KA24DE Lightweight flywheel 12lbshttp://www.sikky.com/view_item.php?id=133&catid=16
Nistune Type 3 Packagehttp://www.autovaughnperforman...id=73
ISIS Dual N1 Exhaust - Nissan 240sx 89-98http://enjukuracing.com/produc...{3}41
NISSAN OEM KA24DE ENGINE OIL PAN 240SX 1991-98 S13 S14 (for welding the bung for turbo oil return)http://cgi.ebay.com/ebaymotors...A1318
White 7 Color Water Temperature Gaugehttp://www.glowshiftdirect.com....aspx
White 7 Color Oil Pressure Gaugehttp://www.glowshiftdirect.com....aspx
White 7 Color Oil Temperature Gaugehttp://www.glowshiftdirect.com....aspx
Universal Triple Gauge Single Din Radio Face Podhttp://www.glowshiftdirect.com....aspx
KOYO 53MM 2-ROW ALUMINUM RADIATOR: 240SX S13 KA 89-94 Item#: R1276http://cgi.ebay.com/ebaymotors...ories
Oil Feed:NISsport Oil Pressure Adapter for 240SX 1/8 BSPT (male & female) & 3 1/8 NPThttp://www.nissport.com/catalo...tions
Steel -3 AN to 1/8 NPT 961603http://www.anplumbing.com/shop...Steel
36" -3AN Line 63010136http://www.anplumbing.com/shop...-Flex
0.03 Oil Restriction Inlet Fitting Turbo Restrictor GT28/GT28RS/GT30R/GT35R. Output is -3 AN male OILRESTAK2http://www.takamotorsports.com/
Reference:zerothread?id=312476http://forums.nicoc ... ead/276957
Oil Return:Swivel-Seal 90 deg. Tube Hose End -10AN 809110http://www.anplumbing.com/shop...-Seal
Swivel-Seal Straight Hose End -10AN 800110http://www.anplumbing.com/shop...-Seal
981610 Straight, Pipe Thread To A.N. Adapter 1/2 to -10ANhttp://www.anplumbing.com/shop...minum
967110 Steel Weld Fitting -10ANhttp://www.anplumbing.com/shop...!_Ons
400100 Premium Racing Hose. THE BEST! Use Swivel Seal or Auto-Fit Hose Ends -10AN 1-foothttp://www.anplumbing.com/shop...-Flex
GT Turbo Oil Return Flange w/ -10 AN Fittinghttp://himni-racing.com/index....vnp77
Reference:zerothread?id=140446https://www.dwperfo ... m/...t=100
Turbo coolant lines:Banjo Fitting Kit for coolant lines - 14mm Machined Alum to 1/4" NPThttp://www.atpturbo.com/Mercha...=GTBB
Fitting, 1/4" NPT Male to 5/16" Hose Barbhttp://www.compperformancegrou...tting
Goodyear Replacement Belts and Hoses 65127 5/16 in ID. Hose 25fthttp://www.summitracing.com/parts/GTR-65127/
Reference:http://www.sr20-forum.com/240s....htmlh ... com/ansize
Water temp Adapter:NISsport Water Temperature Adapter for 240SXhttp://www.nissport.com/catalo...tions
Reference:http://pivotjp.com/product/ins....html
Oil cooler:GReddy Oil Cooler Adaptor W/Thermostat 12401123http://www.240sxmotoring.com/groilcoadw.html
"-10 AN Male to 1/2 in. NPT Male adapter fittings RUS-660500 (Quantity: 2) $3.95 each"http://www.summitracing.com/parts/RUS-660500/
"-10 AN Hose to Female -10 AN straight hose ends RUS-610040 (Quantity: 2) $9.95 each"http://www.summitracing.com/parts/RUS-610040/
"-10 AN Hose to Female -10 AN 90 Degree hose ends RUS-610180 (Quantity: 2) $21.95 each"http://www.summitracing.com/parts/RUS-610180/
"Hose, ProFlex, Braided Stainless Steel, -10 AN, 10 ft. Length RUS-632170"http://www.summitracing.com/parts/RUS-632170/
"1/2 in. NPT,5 3/4 in. x 11 in. x 1 1/2 in. fluid cooler B&M 70273"http://www.summitracing.com/parts/BMM-70273/
Summit® Fluid Cooler Mounting Kitshttp://www.summitracing.com/parts/SUM-G4990/
Reference:zerothread/167442http://www.240sxforums.com/for....html
NISSAN EGR BLOCK OFF PLATE TURBO 240 SX KA24http://cgi.ebay.com/ebaymotors...ories
Oil Catch Can Setup/PCV setup:
TBD
Reference:zer...46254http://www.ka-t.org/forums/vie...c7952
Originally, I want to get Garrett GT2860RS turbo. However, it seems like S15 OEM turbo will be cheaper and easier to setup (can use SR20DET bolt-ons).
There are my original threads:http://zilvia.net/f/engine-tec....htmlh ... or...01605
1) Will my setup work? Am I missing anything? I am looking for a complete list.2) What are other suggestions? Please no engine swaps. I just want to build my KA-T.
All the work will be done by me and my friend. The only thing I need from a welder is to drill/weld the bung for turbo oil return on the oil pan. I will road tune my car with Nistune myself, and I am still reading a lot of things for ECU tuning.
Please contribute. I think this will help alot of new people who wants to turbo their 240SX.
Thank you!
xrproto07
Car: 96 S14 zenki
Looks like you have your stuff together man
You are pretty much right on track
And your set-up will work with the emphasis being on the tunning other then that you look like your setup is gonna be a fast spooling responsive set-up
trackslut240
Car: 1993 Nissan 240SX
wow you definitely did ur home work!! kudos!!
hey buddy skip the glowshift 7 gauges...they will crap out on you right when you need them. also why not go with bigger injectors which will give you a little more potential coz once that boost bug bites...u just have to bleed profusely....an adjustable fpr and a gauge to keep an eye on fuel pressures, also gives you a fine tuning angle. nistune is prolly the best one out there now for self tuning. i have the bikirom which took a crap on me precisely when i went turbo. ... so am waiting for it to come back from australia. support is not one of the best avenues most of these board tuning stuff has. but if you have it setup properly, u can have all the features of the big boys and then some. good luck with the build and keep us posted.
supra33202
Do I really need JGS Vacuum Block? How do you guys run the vacuum lines? I know I need vacuum for BOV and boost gauge. I am confused now.
D-UNIT
Car: a 91' S13 (15.014 @ 94.56mph NA) KA-T
I would run the S15. I seen a fully built SR hit 336whp with that turbo. I have a gt2860r ( actually a HKS gt2530r same thing ) S15 specs are pretty much the same but can't beat the price. If U were going the GT route I'd say at least get a gt2871r. But the 2860r (s15) is spooltastic. I swear I was hitting 8.5psi at 2800rpms for about 230-240hp to the wheels. Yeah you are going to need an LSD!!! btw I would just get the JGS tools gt oil line kit , I did that piece mill crap and pretty much spent over $150 on fittings and lines.
GTR PrYdE
Car: 1993 Nissan 240SX, 2003 Evolution VIII
supra33202 wrote:Do I really need JGS Vacuum Block? How do you guys run the vacuum lines? I know I need vacuum for BOV and boost gauge. I am confused now.
I run a JGS vac block, works great. I used it for bov, wastegate, fpr and boost gauge with it. Works sooooo much better than T's everywhere.
240sxvaj
Car: 1991 240sx fastback KA-T- SOLD!
1994 MKIV TT-Daily/Track
Not bad for your set-up. the only thing about a T2 turbo is that it will be kind of restrictive for the KA Motor, which might have air overlapse through your cams. For your power level you should be fine with the GT2860rs,
if you're plannin to get the N60 maf then i preferre N62 so that you wont have to upgrade later.
I think the HKS BOV should come with the recir. piece.Shuriken Battery? sounds like StreetFighters LOL...If you want a smaller battery and dont want to relocate then you can get a Lawn Mower battery. got mine from autozone and lasting me 2 yrs so far.The manifold should last for a bit, usually cracks more when car isnt tuned properly resulting in really Hot EGT, vibration,..etc...
and why are you buyin turbo inlet pipe and also getting the Egay air intake system that comes with inlet pipe. depending on the turbo if its the S15 T28 then you would need the inlet pipe w/ 2 bolts but you would need clockin plates if you want to use the s13 hotpipe and turbo inlet.Go to the junk yard and get an oil pan, it would save you a lot of $$
Also when i did my set-up i had to extend my cat a bit due to the position of the manifold they don't line up like the sr20's, but try it out first you might get lucky.
Also use HUmp Hose Couplers when necessary for your egay intercooler since i'm pretty sure fitment isnt going to be perfect.
One thing that usually go bad in a lot of older s13 is the fuel pressure regulator, so if i were you i go aftermarket something like aeormotive and fuel pressure gauge.
Also Walbro fuel pump and a z32 fuel filter.
Remember one of the most important part is your tune. GL
supra33202
240sxvaj wrote:Not bad for your set-up. the only thing about a T2 turbo is that it will be kind of restrictive for the KA Motor, which might have air overlapse through your cams. For your power level you should be fine with the GT2860rs,
Do you know where I can buy a clocking plate?
Thanks!
supra33202
trackslut240 wrote:wow you definitely did ur home work!! kudos!!
Thanks for the suggestion of monitoring fuel pressure.
I think I will do:
zer...age=1
Modified by supra33202 at 8:43 PM 8/30/2009
D-UNIT
Thanks!
heres a few!
http://www.phase2motortrend.com/tuac.html
http://www.enjukuracing.com/ni....html
supra33202
Thanks for the help!
I've been googling for clocking plate, but the official name is called clocking adapter. No wonder why I can't find it. lol
D-UNIT
Haha no problemo! Who needs google when NICO advertisers have everything you need.
supra33202
Do you guys think getting a TurboXS Knocklite is agood idea? Some said it's unless because the knock light is too sensitive, and can't tell if they have true engine knock or not.
supra33202
For the oil feed/return, I think I'll do this:
NISsport Oil Pressure Adapter for 240SX 1/8 BSPT (male & female) & 3 1/8 NPT (One 1/8NPT for oil feed; One 1/8NPT for oil pressure sender unit; One 1/8NPT for oil temp sender unit)http://www.nissport.com/catalo...tions
KA24(D)E T25/T28 Oil Line Kithttp://www.jgstools.com/turbo/...98149
0.063" Oil Pressure Orificehttp://www.jgstools.com/turbo/...98149
Garrett GT25 GT28 GT30 GT35 Turbo Oil Drain Flange Kithttp://cgi.ebay.com/ebaymotors....m245
This setup will be cheaper and simpler (no need to cut stainless steel lines).
tctomasc
Car: 95 240sx
just an FYI, the recirc fitting is seperate for the bov. You don't really need that vaccum block... if your removing the egr, then that free's up a port right there.
