GEO wrote:Koyo dual radiatordual electric fanoil coolertranny cooler
Koyo is not a good radiator for road racing I'm afraid.
I would go with a C&R dual pass for track usage. I'm gonna have to make due with my Koyo by basically mediating air flow. You can do this by boxing in (ducting) air and forcing it through the radiator.
As far as coolant is concerned you should run primarily water. PG and EG are two substances that can cause alot of wrecks should you spring a leak. Alot of tracks look down upon coolant in the cars, which is why most racing series' don't allow it.
Electric fans are worthless on a track car for the most part. You DEFINEATLY want to stay away from fans that have shrouds that hug the radiator, such as the FAL 210's. At speed the shroud will stagnate air behind the radiator core and reduce airflow. At SPL we tend to use FAL 150's which flow more, are lighter, and have a deeper shroud.
Make sure your hoses are as short as possible and aren't getting soft when hot. This can restrict the flow, and can be an issue thats hard to diagnose.
Thermostats are worthless unless you are overcooling.
Oil cooler is a given. The KA and SR hold meager amounts of oil, and ask it to put up with alot. I would run a thermostat off the block, and route it to a small - medium sized oil cooler. Remember you might hit road debris or go off course so be sure to protect the oil cooler at all costs. I think behind the intercooler would be a decent place, and route air via a duct to it. While not ideal for airflow and cooling it would be beneficial in the event of a wreck because the engine would stall once the intercooler was crushed.
Trans and diff coolers are nice, but with the cost of a replacement it's honestly just better to run without them. You can get a differential cover that's finned off ebay for cheap.
At least you are in Toronto, it's not like you will be fighting with nature as well.
