KA-T running weird
troll's 240sx
Can someone help me out, I am just a little confused. Just got done putting the turbo in my car and it seems to run a little rich even when stock injectors and it bogs out constantly. Ive checked for vaccum leaks but I havent checked too good on my IC pipings yet. The only vaccum found was the one that goes to my IACV anyways. I do have a small exhaust leak at the end of my downpipe though, and thats about it.
Heres my setup. A 95 ka24de with a T04x turbo with .48/.60 A/R, custom 3" downpipe, Z32 MAF, JWT Fuel Rail, 50lbs MSD injectors (currently running stock so it wouldn't flood), walbro fuel pump, Greddy BOV vented to atmosphere, JWT ECU, and a plugged up EGR port. Still waiting for my adjustible FPR and my iridium spark plugs to get here.
KATwo40
Car: 1993 240sx KA-T
FWIW: I ran my KAT setup with 370's, SAFC and stock fuel pump. Ran fine, but was leaning out a bit up top under 7psi. After putting the Walbro255 in, it ran pig rich. Some swear that it won't cause that condition, but I know for a fact it did. All the settings had to change with the high flow pump.
You could pop your stocker back in for testing purposes and see if it clears up.
troll's 240sx
thanks alot. you just reminded me of something important. It makes sense now. The bigger fuel pump, pumps more fuel but you got to have something to control the pressure, which where the adjustable FPR comes in to regulate the pressure. Without it, it will pump out max pressure at all times. Thank you, and I will let you know how it went when I get my FPR in.
Jookmasta
nope thats a hit and miss situation. im running a 300zx tt fuel pump with no rich issues except for if my afrs dip. CHECK THE IC PIPING!!!!!!!!!!!!!
my car did the same thing, go over ur ic piping with a microscope if need be but check all couplers. do the jiggle test; if ur hotpipe or cold pipe has any play on any part of it, theres a good chance that u have an IC piping leak between one of the couplers....................
nissanfanatic
Car: 1992 Nissan 240sx SE
I ran my walbro when I was NA. No problems here. Stock fuel system. I woudl check fuel pressure.
DammitBobby
Car: S13 91 KA24DET
troll’s 240sx wrote:Can someone help me out, I am just a little confused. Just got done putting the turbo in my car and it seems to run a little rich even when stock injectors and it bogs out constantly. Ive checked for vaccum leaks but I havent checked too good on my IC pipings yet. The only vaccum found was the one that goes to my IACV anyways. I do have a small exhaust leak at the end of my downpipe though, and thats about it.
JWT ecu is designed for a certain fuel pressure, injector size and MAF. If I am not mistaken JWT uses the Cobra MAF.
Jookmasta
actually JWT can program the ecu's for either stock MAF, cobra MAF, or z32 maf.
troll's 240sx
Checked all my pipings yesterday, found a leak and fixed it, then a little pin hole leak at my bov flange that this guy welded for me, stuck in my 50lb injectors and setted my fuel pressure down to 40 psi now. Was at 60 psi when before. It is still running like it is misfiring, and would not keep an idle when you gas it. Does my egr control solenoid have anything to do with it? It is still plugged in but the vacuum lines are just left open. I'll try to get pics of my setup later.
Jookmasta
pics would help. told ya it was the IC piping. I think it could b the ecu or check ur MAF. could also be the IACV. and what is ur timing at and what do ur plugs look like? just throwing sum suggestions till ya post the pics.........
troll's 240sx
how do i post up pics.
my timing is at stock 20 degrees and my plugs are dark like it is still running rich.
Modified by troll's 240sx at 3:54 PM 3/31/2005
