Riubens wrote:yeap put the iat back inn,changed the MAF sensor and changed the ECU to another A/T ecu because my friend couldn't find my 5speed ecu,car runs better.but it still runs rich after the car has run 15 minutes or so, and this new ecu is giving a new code which is code 77(rear 02 sensor) and 84(A/T communication line).what gets me mad is that when the car is cold I have the s-afc -27 across and the afr's are perfect but after the 15 minutes I have to change the LO settings in the s-afc to -40 from 2000rpms forward to get a decent afr ratio while cruising!
so could the rear 02 sensor cause this?? I thought it was for on board diagnosis only. if so could I plug it with the analog out of my wideband cause am not sure it will work for the rear o2 sensor, any inputs on this???
and also would the A/T communication cause this ?? I though this was basically the the speed governor?? or am wrong! any inputs on this also??
thanks you guy's.
Aha, it's weird that your old A/T ecu wasn't picking up that code 77.. Good job on replacing it though..I am almost certain that you're having an O2 sensor problem (most likely with the rear O2 sensor since you're getting that code 77). Oxygen sensors are required to perform a critical function on your vehicle in the harshest of environments: Measuring the oxygen content of the exhaust just after it leaves the cylinders. The oxygen sensor has to accurately check this hot exhaust hundreds of times per minute and send that data to the vehicle computer. The fuel/air mixture "hangs" in the balance, and the symptoms of a bad oxygen sensor: Black smoke from the exhaust, a rotten-egg odor, and poor performance and fuel mileage are exactly what you’re experiencing, right? A new oxygen sensor should fix the problem.
