ka-t ques
shift0246
Car: nissan 240sx
yoo im looking to drop in a s14 ka motor into my s13 an d dureing the process turbocharge it with a top mount turbo would this setup fit under my hood?
DammitBobby
Car: S13 91 KA24DET
The only difference in S13 motor and s14 motor: Head, valve cover, valve cover bolts, upper timing chain cover, intake manifold.
If you use the S14 head you have to use S14 head, valve cover, valve cover bolts and upper timing chain cover.
Difference in the intake S14 does not have the butterfy valves.
Chezedik
Car: 1991 Nissan 240sx
So yes, it will fit. The bigger problem is generally Master Cyl clearance.
