ka-t problems
drunkmonkalan
so i started my ka-t on my 1996 240sx and was wondering:
i have a stock motor and just hook up my turbo + manifold + intercooler system + oil feed/return + mafs, will this thing be able to idle at least? I have not done any timing or fuel management yet... i have timing and fuel controllers in my garage, but i just wanted to see if it would idle with no problems.
so i did all this and it is not idling properly... starts fine and idles for a few seconds, then bogs down and dies. though in the few seconds, it even revs.
here is my setup:
td06 greddy manifold greddy IC for s14 oil feed/return blitz bov
jeff420
Car: too many to fathom
how is it a problem? seems like user error to me. you halfway installed the kit and it doesnt run right.......your gonna need a rom tune or at least an safc to control that maf. a rom tune and some bigger injectors would be ideal.
drunkmonkalan
yes sir, i have all that stuff, but just wanted to see if it will idle. this other guy told me it is my mafs. this makes alot of sense bc i have z32 mafs and it is hard to find a wiring diagram for obd2 s14. ill have to go look around
shimizu_17
Look on Jim wolf technologies website for a wiring diagram for Z32 maf onto 240sx.
WDRacing
drunkmonkalan wrote:so i started my ka-t on my 1996 240sx and was wondering:
here is my setup:
Do you have bigger injectors? Why would you want to "idle" the motor? You need to do some serious reading man. I see a "blew my motor" thread in your near future.
WD
GEO
Car: 95 240sx KA-T
First of all, the MAFS voltages are screwing with your ECU and its jsut dumping fuel into your motor in response.
drunkmonkalan
hey WD,
I have 650cc injectors (AMS fuel system), innovate lc-1, and megasquirt that I have not installed yet. I am just trying to take baby steps. i wanted to see if it will run with just the turbo piping installed, bc i have no idea if i did it right.
actually, my goal for doing it in baby steps is already working bc i would not have known that i did the mafs wrong. then i would have to go back and say "ok... is it the megasquirt? did i install the fuel system correctly? etc"
i am starting to realize that megasquirt is prob too much for me. i will try to get emanage ultimate instead... i heard good stuff about it.
