WDRacing »
https://forums.nicoclub.com/wdracing-u3125.html
Wed Mar 29, 2006 4:05 am
Well, you need a wideband to adjust the fuel. The narrow band will ALWAYS bounce when the car is warmed up because the ECU is now using the O2 sensor to control the AFR, since your car isn't tuned yet, the stock O2 and ECU are confused.
I have to say this for the record. Make sure the settings on the SAFC itself are correct, like the arrows and maf type etc. Then while the car is idling, lean out the mixture with the safc at that rpm level until it starts to stutter. You can take away to much fuel and cause your motor to die by the way, I did it myself. Once you get it to start stuttering, add a few points on the safc until it runs smoothly. Then do that same thing again once the car is warmed up.
Then for the other settings, take away 25% accross the board. Stay out of boost and drive your car to a dyno and tune it with a wide band, or beg borrw or steal a wideband from a friend.
Have fun in Guam, watch out for the Team Anderson SP's. When I was there in 98 we streaked the golf course...they were non to happy.
WD
