trackslut240 »
https://forums.nicoclub.com/trackslut240-u19336.html
Fri Oct 30, 2009 2:52 pm
go all out man, plug up egr, remove all the hoses associated with egr.plug up all the pcv ports on manifold, requires drilling retapping, disassembly of intake manifold. if u want to still use stock location of pcv, make sure the pipes on there with clamps on them, coz if the come off, u will need tiny hands to get them back in.(advise putting a catch can between block and manifold for pcv.(read up on it, its a little more work but keeps the intake clean.)keep iacv, air regulator, ficd and what not to have it idle properly. make sure u clean the manifold and iacv real good, i mean real real good.make sure anything connecting to vacuum source on manifold can be either used properly or blocked. developing a vacuum leak once u go turbo is a pita to catch...
