fiznat wrote:looks nice man! whats your setup like? how are you managing fuel and timing? what mani do you have, whats up with that huge oil feed, etc, etc, etc... lets hear it!
rco8786 wrote:Ok you've got me confused...the smaller braided line running to a 90 ontop of your turbo is your oil feed right? I see some other braided lines in front but can't see where they go, so ill assume those are your coolant lines. If you could post a pic of your oil pan when you get a chance that'd be cool, ive been trying to figure out the best way to do it..
fiznat wrote:ahhhhh thats cool man, wet bearings! thats what I want to do also. tell me, where did you hook up the inlet and outlets for the coolant?
I ran them off the throttle body coolant lines. easiest way i could think of....
how much do you plan to boost?
j-z wrote:hows spool time with the .63 a/r? also how does it run with the non-recirculated bov?
sil80drifter wrote:Wow you car looks really clean inside the engine bay and outside of itI am wondering where you tapped in for the coolant lines?
Answered this down the line some, but the TB lines- because it was easy.
What's your compressor size on the T3? Your turbo looks very similar to mine off of a 2nd gen RX-7, with huge turbine and smaller compressor. Almost a reverse t3/t4How much are you boosting, and when do you get full boost by?
It's a Nissan turbo- i believe from a 300zx as the turbine it came with had a wierd exhaust elbow that looks similar the the passenger side from one. I replaced it with a new turbine and WG assy to keep my ac and ease of mounting. I think being a Z turbo it's AR is 60- not 100% sure though as it's not marked anywhere- Is anyone good with Id'ng those things i can give them all the info cast into the compressor???
I already use an AFC and plan on getting the BTM from MSD. Which BTM did you get? And for what reason?
The universal one- because i wasn't running an msd igniton already.
The JGS manifold, did you get it complete or just a "log" without a flange/exhaust flange and made the piping urself? I am ordering mine from them too, but I need just the exhaust flange as I'll be welding the rest myself.
I got it unfinished (as a log with the flange separate) and welded and ground it out myslef. I welded all the intercooler and exhaust piping from steel U and 45deg bends. Got the 3 bolt tubo exh flange from ebay for like $25
Sorry for so many questions, but this is very very interesting to me as a fellow KA-T do-it-yourselfer
Love talking about it- never mind questions! I got a lot of info from this board (didn't even think about KAT until i saw it) and i'm trying to give some back now.
goldenchild wrote:how many miles are on the engine. Ill be boosting soon, fmic, fmu, rfl bov, gauges ,walbro pump, jgs manifold, t3/t04b, tial wastegate
Jonny 290 wrote:LOVE the matched piping colors. Very nice touch!
Have you considered picking an E-Manage for your SAFC?
node wrote:LongIsland240 ,
Hey Im from Port Jeff originally.
Couple of questions. The fitting on the oil pan, is that just one of those brass ones at home depot? To hook up the braided rubber hose. Did you use the oil drain tube fitting that came with the turbo, or did you thread in a new fitting?
