Chezedik »
https://forums.nicoclub.com/chezedik-u3691.html
Tue Aug 28, 2007 6:37 pm
For 3K, I would piece together my own kit, and rebuild the engine and drivetrain with the good stuff, or you WILL spend more later. You could probably build the engine for 1K or a little more depending on your power goals. Then, I would get a better clutch, again depending on your goals.
Then engine management, this is the deal-breaker, so if you remember those power goals, you can make a rational decision with enough research. But when you set your goals, be VERY realistic. If you underestimate your needs, then you will find yourself in a money pit in a hurry, just as many of us have.
Finally, worry about your turbo setup. You can find deals if you look in the right places, but I would not suggest going cheap with the mechanically intensive parts, or if you do, be sure you go with the names, and find ways to go cheaper.
This will be a stretch at 3K if your goals are stout, but if you can realistically live with 200-250hp, then you can pretty easily stay in that budget.
Myself? I know I will want LOTS of boost, so I have a cheap turbo which will get me DD'ing for a while, then I am thinking of stepping up to a 60-1 or so with bigger injectors. But given my experience, if I would have spent the money the first time, I would not have spent so much in total. Learn from our mistakes via the SEARCH function, and you won't be one of those (like me) that two months from now decides SR should be the way. If you aren't willing to take the proper steps, then an SR is for you.
