klattr1 wrote:about the hp vs torque figures, only time you see SR's matching hp and tq is when they have close to stock turbos peaking out boost at peak tq and boost dropping off towards redline (will definitely offset it). otherwise, with big turbo setups, its usually far off (makes sense for engine design though). with the KA, usually hp and tq are pretty close depending on size of turbo and turbine AR ratio choice. also, notice Rick has a short runner intake manifold which is guaranteed to pull down the peak tq some for higher rpm HP gains.
Like I said before, up til the 300 - 320 mark is when SR's start to deviate from the peak numbers being similar. Mainly because the turbos start getting big enough that peak boost is seen later in the RPM and setups start to get more and more top end focused. While it does shift the peak numbers higher up, you run into a wider torque band rather than the big peak numbers.
The majority of the difference lies in spool-up being primarily before the engines peak VE and the engines inate ability to just churn out good low end grunt. Just a benefit of the KA.
Oh and if $2200 is installed with the cost of the TT g'box then that is a pretty good deal!
