KA-T on the vert. Show off what you got.
1SickSilvia
Car: 1992 Nissan 240sx vert
Hey guys, I was just wondering if you guys could post up pics of your engine bay if you got a KA-T in your vert, with detailed specs of your setup.
I'm planning on going boost this winter on my KA and I have read up on the topic all over Nico and Ka-t.org so much that my head hurts. However I still cant make my mind up on which way to go. The more I read about it , the more questions I have, lol. Which turbo, ecu, injectors, etc.My plan is to be arournd 300hp , mostly for reliable weekend fun, and maybe some track time as well. My budget is around $3000.
I'm thinking about getting a T3/TO4E turbonetisc turbo ( .60, .63)running around 10 psi, megan bottom mount manifold, 550cc deatchwerks injectors, FMIC, Enthalpy ecu, blitz wastegate, walboro fuel pump, z32 MAF.I'm kinda stuck at that point.
-Does that setup sound like it would meet my horse power needs??? - -How close are the SR intercooler pipes to what the KA motor needs, can they be used without alot of fabrication?
-What other SR parts are usable for a KA-T?
-would a T28 turbo be better than a T3/TO4E for my plans?
I'm asking you guys because the vert forum is a close community more so than the other ones that I've been to. Any advice is greatly apprechiated.
1SickSilvia
noone??????
Silvia_Drift
Car: 1989 Nissan 240sx Coupe
Check out the second page of my thread for my KA-T install:
zer...age=2
I have since gone FMIC with custom piping. There was way too much heat soak with the SMIC.
TonyStarks29
Car: 1994 Nissan 240SX Convertible w/ SR20DET
your able to use stock SR injectors on your Ka
DeXteR
Car: '14 Nissan Titan Pro4X
'05 Nissan Xterra OR
'92 Nissan 300ZX Slicktop
'94 Nissan Sentra RS Rally Car
I've got a pile of engine parts right now... Just need some ARP hardwares before I take the good ol' KA to the machine shop.
Greg, how are those ebay SR pulleys holding up?
tennisitis
Car: 92 black convertible
My 92 Black convertible has the Greddy setup with a td06-20g turbo, fuel rail with 370 cc injectors, Greddy Emanage ecu, fresh dyno tune, irdium plugs, new wires, z32 fuel filter, z32 MAF, aluminum catch tank, stainless fuel lines, brake lines, q45 brakes, 12" drilled and slotted rotors, Seechi control arms, ST sway bars, 17 x 8 Chromes, 595 Federals, Greddy intercooler, custom piping, Walpro fuel pump, relocated battery, Optima Battery, New boost, AFR, oil pressure gauges, new top, seats and 5 spd from 97 s14, KYB AGX adjustable stocks, Megan Springs( 2" drop), Sony explode and speakers, B & M short shifter, new shift boot, upper and lower tower braces, new carpet..more stuff I can't remember.. next to come, new radiator and fans
tennisitis
see "Gone Crazy" post on 9/1 for under hood pictures.
No issues at all.
nismo27
Car: S14 KA-T + S13 Vert
MY S14, not the vert.
The setup you're thinking about should get you 300hp. The only thing I'd change is the manifold. You need a manifold of good quality so it will last. Cheap manifolds tend to crack, meaning you will need to get it rewelded on occasion.
Good Luck!
