zack240man »
https://forums.nicoclub.com/zack240man-u78775.html
Mon Feb 04, 2008 4:27 am
whats up guys. I took my cousin for a ride in my 240. We made it like 1/4 mile and all of a sudden the engine just freaked out. Its kind off hard to explain so I'll try my best. I was hitting about 70 mph with half throttle, and suddenly the car started to decelerate. I gave it more gas, but no effect. At first i thought maybe coupling had came loose, but usually when that happened i can keep the rpms up enough to get the car out of harms way, this was different, as soon as I put it in neutral and gave it some gas the engine choked out. I couldn't get car to even try to crank, nothing at all. I checked the fuel pump fuse and i can hear it cut on. Checked for spark, all good. Checked all major wiring to allow car to run, all good there. I know the car is getting fuel from the smell. The car was running fine the week before, only one problem starting. For reference here is my setup.
14b turbo pushing 5 psi safely stock injectorsstock mafstock o212/1 fmutiming chain was slightly rubbing at 2800 rpm, but is still pretty new
Please help guys, this is a daily driver, any ideas are good ideas.
