KA-t not running
zack240man
Car: s13 hatch ka24det & s13 coupe sr20det
whats up guys i just got finished turboin my ka but it wont stay running. im using a a t25 pushing 8 psi stock injectors stock ecu stock maf. the o2 sensors isnt hooked up right now. im using a fmu rated at 12:1 ratio the maf is hooked up as a blow could it be because i riped off the emmision on the exhaust or becouse there is no back pressure because there isnt a exhast flage hooked up to the turbo please help
Garrett0x
Car: 1995 240sx KA-T
If the only thing you touched is the MAF, Im guessing it is most likely it. But did you plug the EGR off or just rip it out, if its open you have a huge vacuum leak. On a side note, I would be getting bigger injectors, a 255 fuel pump and a some kind of fuel/timing control on there (better safe then sorry) Good luck on the build. KA-Ts are a ton of fun
zack240man
yeahhh... i didnt clog the exhast emensions that could be it
zack240man
also im running a fmu, do you think it will be alright till i get larger injectors
480sx
Car: 1996 Pearl White 240sx
Just dont push the boost past 7-8 and you should be ok. You got a really big fmu, the norm is 8:1.
Garrett0x
Ya, what 480 said is true, if you dont push it you should be fine, however, if youd like a little extra insurance I'd start saving for the upgrades. I would also add a wideband to the list. Interested how you took off the EGR, did you remove it all from the intake manifold or just cut the EGR tube?
zack240man
didnt really take it off just unbolted it from the exhaust manifold why?also i have invested in some up grades like a safc II and i do plan on buying some injectors and a widband next week
Zippy69
Car: 1993 240sx coupe
It sounds like you may have several problems compounded. Your O2 sensor should be hooked up so your ecu knows what is what. Double, nay, triple check all your emissions set up to make sure you don't have a serious vac leak. that FMU may be too big. Your ecu is also set so that if it senses something wrong, it goes into safe mode, where your injectors fire all the time and that could cause a rich condition. Step back and take a long look at your set up to see where something is wrong. G/L
WDRacing
This is a perfect example of why the KAT gets a bad rep. You can't simply unhook things that are required for the car to run properly.
Is the MAF blow through? Cause your wording is...well not good.
Hook up the O2, hook up a down pipe, hook up the emmissions stuff or block off all the ports. Get a 8:1 FMU or 10:1 at most. A 12:1 is going to foul your plugs within a day or two.
Here's the deal when turbo charging a car. Everything that made it run stock will still be needed to make it run with boost. The turbo is just a way to force air in.
Fix ALL of the above and make a new thread if it isn't fixed.
WD
