esahuque wrote:well if everything you did was done correctly, I would do a compression test. What kind of maf are you running? what are you using to tune with? whats your setup?
sr t25, n60 maf, emance ecu, vafc2. i havent checked compression yet but while cranking with the plugs out i can feel air rush out the cylinder
wd-with the crank pulley on tdc mark, both cams lobes on exhaust and intake were facing their manifolds on cyl 1. when i put the dizzy in, i had the valve cover off and i lined up the markings on the gear and shaft. the cap went on right over with the rotor on cyl 1. i checked the plugs a few times but there was always a slight film of gas on it. the funny thing is that i pulled the rail and checked the injectors for pulse and none of the orings leaked.
