esahuque »
https://forums.nicoclub.com/esahuque-u20709.html
Sun Nov 09, 2008 6:18 am
-CP 8.5:1 89mm Pistons ( not needed for 300hp but a good idea if you are rebuilding anyway)
- Eagle rods (stock good till 400whp???) (not needed for 300 hp)
- ARP 12pt head studs (great investment)
- B.C Valve springs/retainer kit (not needed for 300 hp)
- B.C 264/264 cams stage 2 (not needed for 300 hp)
- Cometic Head Gasket ( stock HG is better IMO, a lot of people have had lots of problems with these gaskets)
- S15 T28 Ball Bearing Turbo with HKS acutator (plan on running 15psi) ( T2 type turbo is not going to be sufficient for 300 hp, T3 type turbo is a perfect match for the ka. and if you are giong to run a T3 type turbo you are going to need a wastgate and dump tube) - SS Turbo lines and all gaskets needed (needed)
- Megan racing bottom mount KA24DE/T3-T4 Flange Turbo Manifold (not going to work with the T28 do to the fact that the T28 is a T2 flange turbo) - Blitz Nur Spec Exhaust system (The Knock off N1 exhaust from ebay is the best bang for your buck, the blitz exhaust is way over rated and over priced IMO)
- Megan racing 3'' downpipe (needed)
- Megan racing Exhaust outlet elbow (needed)
- Megan racing 3'' test pipe (needed but again ebay one would work fine)
- HKS SSQV BOV (nice choice, sounds great)
- Greddy V-SPEC Intercooler kit (once again over rated and over priced, ebay intercoolers works great)
- FRSport Hotpipe with HKS flange ( if you don't want to peace it together yourself fssport will work, but remember that its made for a bottom mount manny, so if you go top mount or log style manny do to the T3 style turbo this hot pipe is not going to work for your setup) - OEM S15 Turbo Inlet/Outlet pipes ( if you keep the t28)
- *SPEC Stage 3 Clutch Kit (needed)
- Apexi Super Intake Suction Kit ( not needed but if you want it)
- Koyo Aluminum Radiator (great upgrade for your coolant system, ditch your belt driven fan and get yourself some electric fans)
- Ageny Power Rad hoses ( not needed but if you want them)
- Z32 MAF with plug (needed)
- Nismo Colder thermostat (great upgrade to go along with the Koyo rad and some electric fans)
- Circut Sports Coolant Resevoir Tank (not needed)
- Megan racing oil catch tank (not really needed but its good to have one as long as you set it up right)
- Nismo 2 way LSD (depending on what you are planning on do with your car, drift, drag, Auto-x......)
- Nismo engine and transmission mounts (needed)
- B&M Short Shift kit (depending on what you are planning on do with your car, drift, drag, Auto-x......)
- NGK Plugs and Wires (NGK BKR7E is what you want, the wires you can stay with stock)
- HKS D1 Oil filler cap (Ummm....... Yeah....... not really needed, you want to spend money on some kind of oil cap, get a magnetized oil drain plug. especially if you are going to rebuild, that way you can make sure that you don't have any metal shavings in your oil that will damage your motor)
- Walbaro 255lph Fuel Pump (needed)
- 555cc Nismo Injectors (needed but if you want to run higher hp in the future, you might want to go bigger)
- AEM FPR (over priced and not really needed, stock works fine for your application)
- Wideband O2 sensor? ( comes with the AEM UEGO Wideband controller/gauge)
- Greddy Emange (not if your going with a tuned ECU)
- SAFC? ( depends on how good your tune is)
- Greddy Profec 2 Boost controller (do i still need a boost gauge??) (yes you still need a gauge)
- Apexi turbo timer (sure if you want one, most people just leave there car idle for a few min)
- Greddy speed cut controller? (not really needed but if you want one)
- AEM UEGO Wideband controller/gauge (NEEDED)
- AEM Oil pressure gauge (needed)
- ECU Tune ( not if your going with a Greddy Emange system)
REMEMBER, this is just MY opinion, people have made more HP on less and other people have made less HP on more. so its all up to you!
