ka-t mixed with a lightened flywheel
UncleBen
Car: '05 Infiniti G35 Sedan Sport
'98 Nissan 240SX LE A/T
'95 Nissan 240SX SE A/T
Opinions please....
Since my ka-t project will soon be in the car, I am wondering if I should invest in a lightened flywheel or not. With the added power and torque, I dont know if the fly would be worth it, what do you think?
tonynalli
i would if i had the money, but make sure your clutch can handle te extra power
UncleBen
ACT Street.....should handle it pretty well. Thanks for your opinion.
Red-KAT
Car: 1995 240sx-se ka24det
I have one and love it... It was great N/A and even better with turbo... I like being able to blip the throttle and have the engine jump.
TheOne
Car: 93 240sx FB
believe you always want less rotating mass, thats where the flywheel can come in:).
S14tat
Car: 2007 FX35
1994 Acura NSX
1996 Honda Accord coupe
1995 S14 KA-T *sold*
the only problem i can think off with having a lightweight flywheel is that you'll stall if you put the car into neutral in too high of a rev.
Structure240sx
makes clutch jobs less hasel since you can replace the friction surface instead of having to run to a machine shop.
its also like intake headers and exhuast. one by itself isnt a huge difference, but together it makes a great combo. underdrive pulley/flywheel/lightened driveshaft
MarkEmark
Car: fully-built '95 240sx KA-T
I'd say it's definitely worth it...
Going from a 28 lb flywheel to an 11 lb flywheel over that large of a diameter makes a pretty noticeable difference...I replaced mine with a Fidanza/ACT street clutch AFTER the car was turbocharged and loved the feel of it afterwards...the engine seems more rev-happy, turbo seems to spool a bit quicker.
Don't worry about it stalling either...I'm sure a LOT of the KA-T's in here will stall if you stab the clutch at a high RPM...just something you need to live with, one of the downsides of turbocharging a car not designed to be turbocharged. The revs drop quicker...but they also climb quicker. Positives def. outweigh the negatives.
Go for it though.
sunnys14
Car: S14
having 91 dual exhaust cams (248 248), lightened flywheel, lightened crank pulley, electric fan conversion, i lost ALOT of low end power when the turbo wasnt spooling.
UncleBen
Thanks for the opinions; I knew that the less rotating mass = good, but don't want to go overboard. I might as well go crazy though, when my motor is done being built I will be driving it NA for a while, to break it in and to still have a car to drive while I piece together a setup. Once the car is boosting I'm wanting to get a daily, so I might as well go crazy with the 240 if it isn't going to be driven everyday....
Thanks again guys, I guess I shall invest in a flywheel!
Ligouri Rd
Car: '96 Nissan 240SX
Quote »I have one and love it... It was great N/A and even better with turbo... I like being able to blip the throttle and have the engine jump.[/quote]I have a fidanza and an ACT Extreme clutch and I caint exactly say that I "love" all aspects of the combination. I dunno if it is just due to the clutch or not, but I feel I have to rev the piss (1500rpm+) out the motor just to get the car moving. Its great once you are moving, shifts are quick, and rev matching is a breeze. Just not great for stop and go traffic...mabye im just whiney cause all the major highways in chicago are torn up, and I have to spend an hour and a half on side streets to get to and from work.
BillKlineVT
Ligouri Rd wrote:I have a fidanza and an ACT Extreme clutch and I caint exactly say that I "love" all aspects of the combination. I dunno if it is just due to the clutch or not, but I feel I have to rev the piss (1500rpm+) out the motor just to get the car moving. Its great once you are moving, shifts are quick, and rev matching is a breeze. Just not great for stop and go traffic...mabye im just whiney cause all the major highways in chicago are torn up, and I have to spend an hour and a half on side streets to get to and from work.
It's definitely not the clutch, I have an ACT Xtreme clutch and it pretty much drives like stock.... kinda makes me happy I didnt get the lightened flywheel if you say its that much of a pain for daily... I love the way this clutch feels
