Structure240sx »
https://forums.nicoclub.com/structure240sx-u1949.html
Fri Sep 09, 2005 1:36 am
looks a bit better than my revhard did
like tat said, slot* the runners using a cuttign tool of some sort and drill out the bolt holes. this will allow for heat expansion and resists cracks greatly. i have had mine for over 2 years now with no issues.
also like mentioned the ports are round. take an exhuast manifold gasket and grind them out best you can, might have to do it at an angle
if you end up with a t4 turbo make sure to open up the manifold outlet to match a t4.
garret, turbonetics, and precision all have on-center turbos avaible. i now have a precision pt61 which im sure you just saw the thread about.
