1sikS13 »
https://forums.nicoclub.com/1siks13-u47232.html
Fri Apr 10, 2009 4:34 pm
I got my KA-T running as some may know but on the way home after cruising i was having misfireing problem steadily getting worse. Well i figured it was the s***ty platinum tip NGK plugs i had in it(heat range5) and i ordered some new ones BKR7E of course. I got em today and its still has the same problem. Basically the car will start, but then if i try to rev it, it will only got to about 3500 and bounce like its a rev limiter. So thinking i read this somewhere i pulled the plug on the maf and when i rev it it does the same thing. Can anyone verify that this is a sign my MAF is junk. BTW its a n62 if your wondering. All my plugs wires cap and rotor are brand new. And im running a MSD blaster coil if that helps any. Your help is greatly appreciated Nico
