Florida240sx wrote:It stop or got worse?
The idle got worse when the turbo was installed. Stock it was solid at 750rpms.
Florida240sx wrote:JWT does know this is a ka24e not a ka24DE correct?
Yes, ECU is tuned for KA24e
Florida240sx wrote:You checked for boost leaks?
Not sure...haven't hooked up the boost gauge to see where vacuum or boost is at. What should vacuum read at stock?
Florida240sx wrote:Checked to make sure fuel rail isn't leaking?
No leaking of the fuel rail
Florida240sx wrote:What color smoke is coming out your tail pipe?
White smoke
Florida240sx wrote:You have new or used injectors?
New injectors
Florida240sx wrote:Do they require a resistor?
No resistors..straight drop in.
Florida240sx wrote:You have another stock ECU?
Haven't tried a stock ECU yet. But with a stock ECU and injectors the idle still fluctuated without a MAF wired in.
Florida240sx wrote:If you clean your plugs and have your mafs disconnected and put in a stock ecu, even with the larger injectors you should be able to start the car. Are stock ones a direct replacement?If so put stock injectors back and get a stock ecu. Make sure car runs correct. You should do this anyway. This rules out everything else except for either your bigger injectors or the ecu tune. So then you go from there. Sometimes you need to back track. I always keep stock parts to start back from scratch in case of an issue.
Haven't tried stock injectors and stock MAFS, it would require resoldering the injectors and MAFS plug back in.
The shop I had it at says the larger injectors with the JWT ECU are causing the car to run really rich (they hooked it up to their wideband).
Modified by JaeTea at 1:00 AM 1/13/2008
