turbo2nr wrote:ok its about that time im wating for a couple of parts to come in and i begin ka-t
i want to do this my self. mainly b/c a shop charges about 600 to install, thats a pretty good price but out of my buget to pay for labor.
my setup will bet04brevhard38mm evolution wastegate3" downpipedumptubeFMIC (22x6x3)i/c pipes ( 6 180degree 2.5 bends)hks ssqvsilicone couplersjgs oil linewarbow 255370ccsafc.
the problem points:
1.tapping into the oil pan -any tips, can it be done w/o removing the pan and w/o a lift
2. re-routing egr into my downpipe b/c i have obd2 ecu.
3. removing the exhaust mainfold.-i dont want to break any studs, any tips to extract them with out breaking them? also am i gona need new studs from the engine to manifold. and the studs for the mainfold to tubo. any special way to install them or just screw them in with lock tite?
4.oil feed- do i have to take off the whole part where the oil filter sits to tap into for the oil feed or can i leave it on the car. it looks tuff to do on the car so how hard would it be to take off?
i think that about it if any one haves anytipes or advice please tell me. thanks for all the help.
Don't worry about the exhaust manifold studs (the ones hanging off the head)...you should have no trouble with them, and it's actually pretty easy to remove the exhaust manifold so long as you have a socket wrench and a regular wrench. As far as studs from the manifold to the turbo, it depends on what manifold you use but most you don't use studs; you use heavy grade bolts. You don't need loc-tite, but you do need a gasket between the turbo and the manifold. Lock-washers are a good idea too.
Oil pan definitely needs to be dropped to weld it; you don't need an engine lift to do this but you do need a good floor jack.
It's not that big of a deal to re-route the EGR tube into the downpipe; mine is re-routed there (OBD II, and I've passed the sniffer emissions in CT). What you can do is weld a piece of bendable (convoluted) steel tubing to the existing EGR tube, and then have a fitting welded into the downpipe so that this tubing slips over the fitting and is clamped down with a small u-bolt.
