KA-T idles, but will not respond to thottle in gear
jae_rex
Car: 90 240, 02 S2000, 92 hatch
This is the first test run of my completed KA-T project. The car idles fine, but when I hit the throttle in gear, I get no response. The FPR is set to 40 psi, and my safc is set to -%22 on lt and -%27 on ht. Do you guys think the running the 460cc are too much for the safc to handle? I know some guys run 440's and up, but it seems like the injectors are flooding when I hit the gas. Should I reinstall my stock 270cc in the meantime and disconnect the safc? Any information would be helpful. Thanks in advance.
torque2go
Car: 90 240sx
you need to take out more percentage/ less fuel. look at your plugs. its probably running very rich. try around -40% and see how it runs part throttle but get a wideband so your not guessing
nb07bcar
I run 460cc and I'm around -50 at 1000rpm and then around -40 for the rest.
