Jeff240sx »
https://forums.nicoclub.com/jeff240sx-u610.html
Sun Mar 21, 2004 6:30 pm
No, you can't have negative pressure. You have vacuum. Measured (by most gauges) in how many inches of mercury is drawn up a standardized tube.There may be a gauge that converts the inHg to psi for ease of use, but I haven't seen one. If yours does indeed make that conversion, please tell me what make and model. If its an autometer like mine, check around the vacuum reading scale for the units.. they're listed as inHg.Also, you simply won't have -20psi of vacuum. -28 inHg is nearly -14psi, which is right on.-Jeff
