rn240sx »
https://forums.nicoclub.com/rn240sx-u12444.html
Wed May 18, 2005 6:38 pm
Well, if ur running STOCK fuel system, u should not be messing with the fuel maps at all..!! The dec-air function has NOTHING to do with idle mixture..
Re-set the afc back to ZERO across the board and make sure the maf settings are correct for stock maf, if that doesnt help, then remove the AFC completly and run in to see what happens..
I thinks Its that Wideband O2 sensor.. I think that narrowband O2 output from the wideband may be bad. Cause i have that same wideband setup and now my idle mixture is 19.9 unless i tune the afc +25% to get it to 14-15... Then it idles SMOOTH as can be.I havent put my stock o2 sensor in yet cause im just plain old F'ING lazy...
You have to do trial and error. I ran into similair problems a couple of weeks back and narrowed down my FUNKY and JUMPY idle to a bad MSD box...But as far as my lean mixture's at idle, i think its the narrowband output from the wideband o2 sensor...
