kazuma »
https://forums.nicoclub.com/kazuma-u22563.html
Sat Oct 21, 2006 11:35 am
did some further trouble shooting last night, my tps was way off it was at like .25 fixed that to .48 and when open its at 4.1-4.2. tried to run the car without the maf and it idled correctly and when i tried to rev it it stumbled and held it self at 1300rpm(thats as high as i went) for a couple of seconds and then went back to 900rpm(still cold). i have a N60 maf and have the following wiring done,
a = nothingb = going to the white signal cord on the harnesc = ground to chassisd = ground to harnesse = power wire going into black/white harness wire
does that sound right?
another thing i think might be an issue is my maf is probably 5-6 inches away from my turbo. i have heard some people say this could be an issue but i've seen many setups running with about the same length away from my turbo. i have a 50trim trubo with .63 a/r housing.
