ka-t Huge Idle Problem
andy53215
Car: 96 JDM Nissan Silvia
I have a Altima with a t3 on it running 10 psi and went the car idles it shuts the car off cause it goes so low.
spooled240
Car: kouki s14
we need more info. on mods and the type of setup on your management, air fuel ratios, drivablility, etc.
Check all the vacuum hoses first, just in case one of them is disconnected, it could be an easy fix
Florida240sx
All about your tune. You should be able to raise your idle by a screw on the mani. Or tighten your throttl cable so your TB is slightly opened...
