KA-T HP poll
1sikS13
Car: 1992 S13 240sx
I am going to dyno my car on saturday for the first time now that it is KA-T. I decided to make a betting event out of it at my work. So I thought it would be interesting to see what the people of Nico thought. My setup includes
stock bottom end S14 KA24DE550cc injectors255 lph walboro fuel pumpssac top mount manifoldOBX T3 60 trim turbotial 38mm wastegate with open dumpfront mount intercoolerHKS SSQV BOV (recirculated)Z32 MAFNGK BKR7E plugs gapped at .2810.2 mm plug wires10.4mm coil wireMSD blaster coilCenterforce clutch Enthalpy tuned ECU for above mods and 7000 RPM rev limitrunning wastegate pressure of 10.5 psi with a 12 psi spike that trails off to 10 Full 2.5 inch exhaust from turbo into hollow dual 3 inch outlet muffler
that is all.
ViciousCesar
Car: '90 420sx Hatch
'kat goes meow'
xX RB Xx
Car: SE3P, FC3S, FC3C.
273 without correction
nissan_star
Car: 2000 maxima se and 1993 240sx vert (5sp!!!)
i put 275 exactly, foo! and i am betting it all!
1sikS13
Car: 1992 S13 240sx
ViciousCesar! wrote:'kat goes meow'
Correction KAT goes ROOOOAAAAAARRRRRRRRRR
xX RB Xx
more like,
BOOM..
o no
there goes a rod.
TheOne
Car: 93 240sx FB
turbo shreds itself and compressor/turbine housing splits in 2?
prolly ~260 or so, depending on condition of engine, my friend made ~280 at 10psi with a slightly bigger turbo, and aem ems before the tuner blew it up cause he didn't know he had to tune the timing.
j-z
Car: 95 240sx
that 2.5'' exhaust is gonna hurt you. im gonna bet (without knowing the condition of the motor or mileage)....
nah fucck that. whats the exact size of your turbo? compression on motor? if its a .63 ar stage 3 exhaust im gonna bet around 272.
asoomal
Car: 2001 Subaru Impreza L 5MT (Daily)
1992 Nissan 240SX SE 5MT w/HICAS (Being restored)
I see no mods relating to the head, and you set the rev limiter to 7000 RPM?
j-z
Car: 95 240sx
asoomal wrote:I see no mods relating to the head, and you set the rev limiter to 7000 RPM?
your point being....??
asoomal
It won't last long, at all.
I'd set it too 5800RPM, maybe 6000RPM's. There's no point of taking it further than that.
Get yourself a fully counterweight crank and some sort of damper if you wanna go to 7000.
1sikS13
Car: 1992 S13 240sx
i guess i had them make it a 7000rpm rev limit for safety reasons. And BTW my motor is clean only 50k on it and compression tested 180 across the board.
xX RB Xx wrote:more like,
BOOM..
o no
there goes a rod.
im not thinkin so
hazer396
Car: 2007 Tahoe, Impala
lol i guess me putting kat goes meow won..now you know your answer LOL
Doya
Car: '95 240sx KA-T
264hp
finalgear
Car: 91 240sx /90 240sx
280 Hp
spooled240
Car: kouki s14
268 whp and 283 tq =]
a ka can handle 7K rpms no problem, the problem is that power starts to drop off after 5500 approx.
cams, ATI dampener and maybe a custom intake manifold will make the ka pull to a lot higher rpms
sunnys14
Car: S14
Run at the track so you can know your trap speed.
That way we can make a better guess on how much power you're making.
KFL
Car: S14
285hp 270ish tq
Patarach
Car: 240sx convertible KA-T
240-250hp 270-280tq if the obx turbo has the same wheel size as a garrett t3. thats at 12psi
i'm guessing 300hp at 16psi
1sikS13
Car: 1992 S13 240sx
sunnys14 wrote:Run at the track so you can know your trap speed.
unfortunately i wont be running it down the quarter mile until the first weekend of june. I will post then.
KFL wrote:285hp 270ish tq
torque seems low dont you think
sommmatt
Car: 1989 Nissan 240SX
KA-Ts often dyno with lower torque.
nissan_star
what did the dyno say?
spooled240
Car: kouki s14
sommmatt wrote:KA-Ts often dyno with lower torque.
kinda depends on the turbo, but most of the time the torque is the same if not more than the hp
