ka-t hiccups backfires hesitates when i hit boost, yes ive searched
slider01
Car: a 1998 jeep cherokee soon to get a 240sx
alright guys just to let you know i have searched and found that possible reasons for my ka-t to be back fireing hesitating on accelaration or when boost hits could be as follows from threads ive read on here: sparkplug wires, spark plug gap, boost leak, intercooler piping loose, or a thrashed maf, now before i go check on all theese thing is there anything else it could be and no the car doas not overheat at all,
Bosrudorfer
Car: S14
I had the same problem, like it was kicking.
Switched my spark plugs to 7 with lower gap and problem fixed.
slider01
cool man thanks but what doas ;move the spark plug to 7 mean??
Bosrudorfer
Car: S14
I went one colder to 7, # BKR7E. I think I set my gap to .28
I could only find mine at a motorcycle shop, after checking 4 auto part stores
Here is a good thread: zerothread?id=319218
WDRacing
Really sounds like an IC pipe coupler has come loose.
egan
my **** was buckling too under boost. i forgot to tighten the ground on the backside of the motor. it was loose and was sparking. so just check you grounds to be sure. haha
slider01
well a new problem came up tonight while i was trying to tuck away all the wireng for my safc2 i had the radio in the car on and ahile i was messing with wires the car starts klicking like crazy under the hood and same with the check engin light to so know i got the klicking to go away a lil bit just by messing with the wires but the car still wont start and now the safc wont even turn on whats up with that? fuse? bad wire connection somewhere? dam!
WDRacing
Pretty obvious you have wiring issues...
Neejay
slider01 wrote:well a new problem came up tonight while i was trying to tuck away all the wireng for my safc2 i had the radio in the car on and ahile i was messing with wires the car starts klicking like crazy under the hood and same with the check engin light to so know i got the klicking to go away a lil bit just by messing with the wires but the car still wont start and now the safc wont even turn on whats up with that? fuse? bad wire connection somewhere? dam!
Is it safe the have the battery connected AND the radio on (power flowing) while hooking a safc up?
slider01
i wasent hooking the safc up i was just tucking the wires away becouse thay where on the floor boards im going to go try to figure it out now
Neejay
slider01 wrote:i wasent hooking the safc up i was just tucking the wires away becouse thay where on the floor boards im going to go try to figure it out now
Ah, ok. Gotcha. So basically you just wiggled some of the wires and crap went haywire?
slider01
yea and the car is still tweaking balls and wont start i hate wires ....my be i should mega squert it??
WDRacing
Might be a bit beyond your skill level bro...
slider01
yea thats what im thinkenn..mybe ill carbarate that bis natch no wires haha
480sx
Car: 1996 Pearl White 240sx
slider01 wrote:and wont start i hate wires ....my be i should mega squert it??
you sir are in fact, hilarious
Stay away from MS if your not a fan of wires.
You still have a wiring issue from the sound of it.
Bosrudorfer
Car: S14
slider01 wrote:yea thats what im thinkenn..mybe ill carbarate that bis natch no wires haha
Sorry I for one do not speak gibberish
slider01
hay guys forget the wire problem for right now..i called a local tuner shop about the symptoms ive been having with the car the back fireng the hesatation on boost and thay said it could be a fuel pump...you you guys think that sounds right?
Neejay
you didn't replace your stock fuel pump with a walbro or equal?
Tx-Sx-FS
Car: S13 KA-T
hope u didnt hurt ur motor when it was running bad if your safc turned off...but mine would turn off and on, check connections real good
slider01
i got the car like it is...im just wondering if those symtoms could be from a bad fual pump
WDRacing
A bad fuel pump could cause the car to stutter yes.
C-Kwik
What spark plug gap are you running? It's a very common problem for newly turbo'd cars as many first time turboers don't truly realize that the increased pressure increases the resistance across the plug gap. It's the first thing i always recommend in this case for this reason and the fact that it's virtually free to check.
slider01
no the car ran good with the sparkplugs that where being used it just started stuttering and back fireng and hesitating when boost would kick in...i was told fuel pump i hope thats all it is...and sometimes the car would stall out and all i would have to do is unplug the fual injecters crank the motor over for 3 seconds the plug them back in and it would start every time.
240sxvaj
Car: 1991 240sx fastback KA-T- SOLD!
1994 MKIV TT-Daily/Track
slider01 wrote:no the car ran good with the sparkplugs that where being used it just started stuttering and back fireng and hesitating when boost would kick in...i was told fuel pump i hope thats all it is...and sometimes the car would stall out and all i would have to do is unplug the fual injecters crank the motor over for 3 seconds the plug them back in and it would start every time.
I had similar problem, the first thing was when i went into boost it seemed like it was boost leak and starts hesitating. put in new injectors and ran great, next thing was that it wouldnt start up sometime. i unplugged one of my fuel line to make sure the fuel pump was working, it shot out gas fine and after that it started up fine. i found out that my fuel pressure regulator went bad causing me to stall and giving me hard time to start up. dont step on the gas pedal and try starting up. i say if you havent check these things then do so. hopefully this helps
red ka-t
Car: s13
I had the same problem when I first went turboed. It sounds like you have a boost leak. Just make a boost leak tester and you'll be golden. If that dont work check the gap on your plugs.
slider01
cool guys thanks ill check these things then get back to you
