sil80drifter »
https://forums.nicoclub.com/sil80drifter-u622.html
Fri Feb 11, 2005 6:48 am
ahem... or get another KA-E, build that outside of the motor and then just swap over, no problems, no headaches. The aftermarket support for the DE consits of what parts exactly? Turbo kits? fuel rails? clutches? These are all things easily attainable for the E. In fact the E already has a top-feed fuel rail. And the clutches are the same as the DEs. The E has just as much potential as the DE, give your power goals, I think Adamhu has proven that, and there are enough turbo kits/ parts out there for the E to make it a very lucrative platform to work with. Some people prefer to get the DE because it's anewer engine, etc. But it really depends on you. I don't see much difference aside from what YOU can get the cheapest. A E or DE block, considering you'll have to pu more work into swapping the DE in than the E. So figure that amount of time and money into the DEs cost when you look for either.
sil80
Modified by sil80drifter at 4:17 PM 2/12/2005
