ka-t has no power???
nismo_power
Car: 91 240sx fastback se
just got my ka-t running and i drove it around the block, okay so when i step on it the rpms go up but the drag and when it gets into boost it bogs then drags some more till it hits 6k rpm then it just cant go no more and stops there???what is wrong there is also no power to even when its in boost because the rpm is dragging so bad...
sr t25370cccomplete exuastfmicnismo fpr type bwalbro fuel pumpemance tunez32 maf
also is there suppose to be something in the fpr when you take the screw all the way out, like a spring or something???because there is nothing there on mine and my fuel pressure gauge is on right after my fuel filter and the fpr is as close to the stock position as possible and my fuel pressure reads 100psi on start up...so when i adjust it the pressure just stays the same until i unscrew it till its almst out then the needle on the gauge just flys back and fourth from 100 to 20psi???what is going on with my car???
240sxvaj
Car: 1991 240sx fastback KA-T- SOLD!
1994 MKIV TT-Daily/Track
im sure its your tune from E-Mance.
put in your stock ecu and see how it runs.
thats what some of my buddies did and i remember they didnt have that problem but then the car wasnt tune
esahuque
Car: 95 240sx KA-T, 04 frontier
i'm sure it's not your tune. put a stock fpr in and see what happens.
-----turbonola-----
240sxvaj
esahuque wrote:i'm sure it's not your tune. put a stock fpr in and see what happens.
-----turbonola-----
why put the stock fpr back on?
i ran the same set-up like his and my stock fpr crap out on me and then when i installed my nismo type b fpr it ran fine.
the walbro fuel pump is too strong for the stock fpr.
kouki_hmongster
Car: Want 97 kouki
you probably have a defective fpr, also after getting the fuel pressure solved then check for bad tune. Do you have a wideband? what were the readings when you installed the fpr? also look at the gauge and when you adjust the screw does fuel pressure respond to it? if it doesnt then the fpr is defective.
i remember reading a thread, a guy had a bad fpr and it was reading over 100psi and fluctuating, he replaced the fpr and solved.
nismo_power
okay so i dont have the cash to pick up a new fpr yet so i swapped out my ecu and to my stock one and it runs like 10x better but not perfect of course...so what should i do about my emance tune???will he reprogram it...
ive been trying to get hold of you 240sxvaj, came to your house today but you were not home...give me call...
240sxvaj
nismo_power wrote:okay so i dont have the cash to pick up a new fpr yet so i swapped out my ecu and to my stock one and it runs like 10x better but not perfect of course...so what should i do about my emance tune???will he reprogram it...
contact jason ASAP and get your ECU re-tune.
zerepdivad
Car: '90 240sx . '02 Lexus IS300
good luck getting ahold of jason........ if you do you wanna ask him why he hasn't responded to anybody else the last few months???
eazye2000
Car: S13 KA-DET
zerepdivad wrote:good luck getting ahold of jason........ if you do you wanna ask him why he hasn't responded to anybody else the last few months???
I've not seen him on AIM either. I got my car up and running over a month ago, and I've not heard anything back. I don't think I'm going to be pulling punches anymore.
WDRacing
Just so I understand this, you now have a stock ecu controlling 370cc injectors? If so, please stop, you're about two shakes from destroying the motor.
Get a fuel pressure gauge, beg borrow steal a wide band, verify everything. Emance hasn't been doing anyone any good as of late, but don't assume it's his fault. If the car runs with 370's and no tune, it sounds like something else to me.
WD
esahuque
so let's get this straight, you've got good fuel pressure now? you've got a stock ecu in w/370's and a z32 mafs and your car runs better. idk but i call bs. z32 and stock ecu's run horrible if at all. with a stock ecu and 370's you motor should be flooding or at least on the verge of flooding. maybe you installed the stock ecu first and now you have the tuned ecu in. idk but i just can't believe a stock ecu fixed your problem w/370's and a z32 mafs still in the car.
-turbonola-
esahuque
damn you wd, you type faster. lol
-turbonola-
WDRacing
esahuque wrote:damn you wd, you type faster. lol
-turbonola-
I'm simply cooler then you are...
240sxvaj
WDRacing wrote:Just so I understand this, you now have a stock ecu controlling 370cc injectors? If so, please stop, you're about two shakes from destroying the motor.
WD
true.im sure aslong as you dont drive your car or start up your car you should be ok.
i was suprise my motor didnt mess up on me when i drove it 2 hours away just to get it tune.
kouki_hmongster
Car: Want 97 kouki
-turbonola-
to clear things up nismo_power is running an afcneo thats why he was able to run the stock ecu w/ z32 maf. yes it is very dangerous to run the stock ecu w/ 370cc but it was suppose to be a test to see if it ran better only. assuming he only did test run which will not mess up the motor unless if driven for long distance. because me and my bro ran stock ecu w/ 450cc to dyno shop and made it back home(dont recommend this to anyone).
i havent talked to nismo_power but maybe his in/out(hotwire) settings weren't correct messing up the way the ecu ran, since it is tune for a z32maf i hope he have the setting for 2in2out on the neo.
but still ecu doesnt mess w/ high fuel pressure, so this narrows down to bad fpr. after fixing this problem, we'll see if the ecu is bad/good.
GTR PrYdE
Car: 1993 Nissan 240SX, 2003 Evolution VIII
silly question but, have you removed the distributor at all? Maybe worng intsall?
nismo_power
no i have not removed the distributor...
believe it or not the stock ecu is running the z32 maf and 370cc better then the tuned ecu was...i didnt say it was running good but way better...and yes it was just a test...i do have a fuel pressure gauge and i waiting to get a little more cash to pick up a wideband...
so today i got the new fuel pressure gauge in and its still doing the same thing...the fuel pressure will not adjust between 20psi and 100psi???when you try to adjust it then the needle on the fuel pressure gauge just flys back and fourth between 20psi and 100psi???
is this right the way i have my fuel system hooked up??
kouki_hmongster
Car: Want 97 kouki
nismo_power wrote:no i have not removed the distributor...
If the picture that you draw is right then you have the fpr hooked wrong. the end of the fuel rail goes into the side of the fpr and out of the bottom piece back into the fuel tank.
hope this is your problem.
nismo_power
thats how i had it before and the car would not start???
