Open4Cycle »
https://forums.nicoclub.com/open4cycle-u1248.html
Thu Mar 17, 2005 5:45 pm
The one I received had miss aligned tubes to ports. The tubes were not butted to the flange and to one another correctly which left gaps inside. Poor welds full of gas pockets. There were also holes burnt through the tubing and filled with weld. I spent probably 8 hours fixing this manifold by grinding, welding, and machining the mating surfaces flat again.
