KA-T...finally
USDM240
Car: 1993 Nissan 240SX Limited Edition 'vert
after a VERY long time and way too much research, the DE is finally turboed. i was going to keep it a secret until the Buford Dam meet this month, but i cant hold out any longer. its a temp setup that was installed and running in 4 days, but it seems to be working well. its leaking a little oil which i will be investigating tomorrow, but other than that its running great. setup is:
-T3 turbo from RB20-E&E T3 manifold-370cc injectors-Walbro 255-EGR block-off-A'PEXi S-AFCII-recirc pipe-VDO boost gauge-3" DP-RB20 BOV (will be replaced with something else shortly)
it sounds nasty. with the JWT cams, it lopes like crazy and almost wants to die out, but at WOT it moves its ***. im guessing its around 210-220hp without an intercooler. the intercooler will be done this week, but i was pressed for time.
the entire cost of this was right around $800. ill get some pics up here shortly. im just lazy.
USDM240
a little update:
the turbo blew up. apparently the wastegate got stuck openon the second pull and the shaft split in half.
oh well. at least the motor is still in good shape. besides, now i can get the big nasty turbo that ive been wanting.
Florida240sx
This on SOHC? And what's E&E mani?
Fergus
Car: '01 C5 Coupe
Its on a swapped DOHC.
Hey Bruce, think using your ingen intake as piping might have anything to do with the blow up? :p E&E is the shop he works at, guessing its a custom fab.
Just wait a few weeks and I'll show you a real Ka-T.
240DRFT
thats pretty good for $800...i really want to turbo my kade i just swapped in. post some pics!!!
USDM240
Fergus - the wastegate stayed open and boosted well past 14psi. and since i was using the RB20 T3, it didnt like it much.
240DRFT - check the pics below. there not the best, but gives you a general idea.
Riubens
Car: ka-t 240 and 99 Q45 t
Hey were you running that turbo with no intercooler ?how much boost can you run safely with out intercooler?
ILikeMy240sx
Car: SR Power
without an intercooler on a KA... I would be really worried if I did anything past 5 psi...
Florida240sx
I think max you can usually run is about 6psi.But that also depends on your engine size.You can use water/alc injection instead of intercooler and get similiar results.
s86d
Car: autocross, backroad racing, and working on 240's
No intercooler setups are good if the turbo is in decent (70+%) efficency range and fuel rich but I say dumb and scary to do so don't go over 5psi as previously stated. I have fmic and I only run 4psi for the moment. -Dave
MarkEmark
Car: fully-built '95 240sx KA-T
For what it's worth I ran 8-9 psi for a year without an intercooler. But I was also running alcohol injection and 94 octane fuel. Never pinged, not once.
Florida240sx
As long as you get it tuned you can be safe.Proven^^^^
virus77
Car: 95 S14, 71 240z, 97 e320
get alcohol injection and your pretty good with no intercooler.
Chezedik
Car: 1991 Nissan 240sx
USDM, I have toyed with using a tbo3 turbo I have from the 300zx (that's right, it's not exactly a t3). How much boost were you running, and what was your max RPM?
brunswick240
Car: 93 240sx SE
USDM everything looks good and i cant wait to see the finished product.
USDM240
Chezedik - i was running 7lbs. dont really know anything beyond that as the wastegate became stuck open on the second pull and the shaft split. im rethinking my KA-T plan right now. ill most likely use a spare block and build it to handle upwards of 600hp. only time will tell.
brunswick - i cant wait either. all i need is more money.
Chezedik
But no detonation issues? What were you running for your timing?
Checkered-Member
Car: 1998 Nissan Altima (modded)
2003 Audi A6 2.7T (stock)
Florida240sx wrote:I think max you can usually run is about 6psi.But that also depends on your engine size.You can use water/alc injection instead of intercooler and get similiar results.
virus77 wrote:get alcohol injection and your pretty good with no intercooler.
It's common to run 50/50 with an intercoolerWithout one...I wouldn't use any alcohol
All it takes is a bad tank of gas and hot day to put a hole in the block
USDM240If you get water injection you could run 8-9psi without an intercooler, so no rush on that part
WDRacing
Do you run water or alcohol on your car?
There is nothing wrong with running straight methonal or straight denatured alcohol. In fact you get a considerable increase in octane and knock reduction with or without water.
Water is free, thats the best thing about it. There is also no set amount of boost you can safely run with any type water/alky injection setup. It varies greatly on the volume of whatever liquid is injected.
Try not to post vague numbers. There is a great deal involved with any subinjection system.
WD
slipnfall
Car: '06 D40
No 'active' cooling on that puppy at all? I keep seeing all these DE turbo's with *reduced* cooling capabilities. I can see replacing a clutch fan w/electric, but elimination alltogether?
Is this anywhere near safe/smart?
Just curious; it certainly does clean up the bay. Sounds like you really pinched the penny for your setup. ::
Chezedik
USDM, who are E&E and what sort of manifold is it? Where do you get it and what does it cost?
Neejay
Chezedik wrote:USDM, who are E&E and what sort of manifold is it? Where do you get it and what does it cost?
E&E Motorsports: http://e-emotorsports.com has a reputation around the Atlanta, GA area.
/threadjack
Bruce, is there a meet Thursday night at the Varsity? I finally got my insurance added.
