oz240red »
https://forums.nicoclub.com/oz240red-u97606.html
Wed Feb 04, 2009 3:07 am
A quick suggestion, if you can afford it right now, get bigger injectors so that you can get your ECU tuned for growth. (believe me, you will want more HP....)
For instance, if you decide you want to put your car at 300Hp, then you should get your ECU tuned for 550cc injectors. That way you have a reliable setup which will get you to 300hp by upping the boost. If you decide you want only 220hp for now, then no problem, that tune will work just fine, just lower the boost or run the stock waste psi and you'll have a reliable 220hp. With 370cc injectors you can't get to 300hp reliably, and even if you change the injectors for bigger ones, the ECU has to be retuned for the bigger injectors.
IMO it's worth the extra $300 that it would cost you to get them from say DeatschWerks.
Good luck with your KA-T
