Edub1 »
https://forums.nicoclub.com/edub1-u34344.html
Mon Nov 13, 2006 1:47 pm
I'm still confused as to the sequence of events. You tried to run a stock exhaust then went to a 2.5" w/ baffled muffler and still got bad results?
For an exhaust, consider that X HP worth of exhaust gas must pass through 1 pipe instead of 2 which is more typical in the 200 plus power range. Also, consider that a 2.5" pipe has has a surprizing 31% less area than a 3". Plus, a baffled muffler = bad.
Magnaflow makes a great straight through, perforated core design wound with SS mesh for ~ $80. I went with that, a few 3" mandrel bends and a local shop.
