jtsarnak »
https://forums.nicoclub.com/jtsarnak-u3215.html
Wed Feb 18, 2004 8:56 pm
Well, my light has come on a few times previously, and everytime it has, I have used the self diagnostic tool on the '95 ECU to read the code (as per the FSM). Everytime the light has come on, it throws TWO codes, one for the oxygen sensor and one for the knock sensor. Neither have ever shown up by themselves and I hear no knock at all when the light is off or once it's been tripped and driving it around with the CEL on. This leads me to believe that the readings from the second O2 sensor are giving the ECU instructions on how to adjust the air/fuel mixture in relation to it's readings, hence the temporary knock issue when the O2 code is thrown. Any thoughts on this? Is it just the brief change in readins that confuses the ECU and causes the knock sensor to tip or is it the case that if I am driving on a regular basis with the CEL light on for the O2 sensor code, my car is running on retarded timing due to the codes being thrown?
